help having issues with hx motor!!!!!!
Old Jun 13, 2005 | 04:47 PM
deesracer's Avatar
Default help having issues with hx motor!!!!!!
I bought this 99 civic from a friend and i dropped a hx motor in it because that's all i had. I am running it off of a p2p SOHC vtec. I got rid of all codes but it repeatedly throws a code 1 and has a sort of a miss and is kind of slugish when vtec is ingaged or during full throttle. So i guess since this is an economy motor does anyone think that the ex ecu is dumping to much fuel or what? I was running just fine in the car it came out of which was a 98. Is why i could'nt use the stock ecu. If anyone has any helpful info please let me know!!!!!!!Thanx
Old Jun 13, 2005 | 07:44 PM
deesracer's Avatar
Any suggestions anyone......really need help or info!!!!
Old Jun 14, 2005 | 04:02 AM
EE_Chris's Avatar
Default Re: (deesracer)
P2P is the Ex ECU?
What O2 sensor are you using?
Yes - I think the Ex ECU is not exactly compatible with the Hx motor which is probably causing most of the 'performance' problems you're having.
Old Jun 14, 2005 | 08:01 AM
snatch's Avatar
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
Yes - I think the Ex ECU is not exactly compatible with the Hx motor which is probably causing most of the 'performance' problems you're having.</TD></TR></TABLE>
I agree entirely. The HX VTEC is different from the EX's, and I would bet that's where your problems are arising. Both are for economy, but the HX is more economy I think than the EX is.
Old Jun 15, 2005 | 02:41 PM
deesracer's Avatar
Well maybe that's my problem.... Does antone in the NW area have a 99-00 HX (P2N) ecu for sale? If so please lmk.......253 988 1337
ELSUICIDA
Mar 17, 2007 07:17 PM
JDM_Spec_SI-R
Nov 10, 2006 05:44 AM
slowerTHANmollasses
Apr 25, 2005 04:05 AM
Kennysr6
41
Jul 28, 2004 07:34 PM
Dream
Jan 25, 2004 03:48 PM
