O2 Sensor question Primary or secondary?
Old Jun 13, 2005 | 10:37 AM
TheNasty0ne's Avatar
Default O2 Sensor question Primary or secondary?
Can you use a secondary o2 Sensor on the primary or the other way around?
Old Jun 13, 2005 | 03:08 PM
Brian Hinson's Avatar
Default Re: O2 Sensor question Primary or secondary? (OoBryan)
Not 100% sure, but I believe you can
Old Jun 13, 2005 | 07:31 PM
Default Re: O2 Sensor question Primary or secondary? (Brian Hinson)
Bump
Old Jun 13, 2005 | 07:41 PM
JDMOrangeFever's Avatar
Primary measures air flow.. while secondary pretty much monitors to make sure other 02 is working after cat... They are a little different .. wouldnt think it would work.. But im not sure.. Anyone ever swapped them before?
Old Jun 13, 2005 | 07:42 PM
EK k kay's Avatar
Default Re: O2 Sensor question Primary or secondary? (JDMOrangeFever)
They are the same, you can switch the primary over to the secondary and vice versa. No difference between the parts.
Old Jun 13, 2005 | 07:43 PM
Default Re: O2 Sensor question Primary or secondary? (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">They are the same, you can switch the primary over to the secondary and vice versa. No difference between the parts.</TD></TR></TABLE>
Thanks
Old Jul 7, 2005 | 09:04 AM
-Trinitron-'s Avatar
I think it depends on the car. Some are the same part number some are not. EK civics do not have the same part number for the two sensors. When I tried to replace my primary with my secondary it only worked for about 3 days. (I am OBD1)
Old Jul 7, 2005 | 10:12 AM
Used2beAb16's Avatar
Default Re: (-Trinitron-)
i dont think you can use a secodary o2 sensor in place of the heated primary o2 sensor. The one is alot more money that the other on some cars.
Old Jul 7, 2005 | 10:24 AM
EK k kay's Avatar
Default Re: (Used2beAb16)
I've swapped them and no problems on my 99 civic. No cels no nothin. Runs just as good as normal.
Old Jul 7, 2005 | 10:31 AM
IHateJDM's Avatar
Default Re: (chowmien)
they are the same
Old Jul 7, 2005 | 02:50 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Trinitron- &raquo;</TD></TR><TR><TD CLASS="quote">I think it depends on the car. Some are the same part number some are not. EK civics do not have the same part number for the two sensors. When I tried to replace my primary with my secondary it only worked for about 3 days. (I am OBD1) </TD></TR></TABLE>
specv5150 wo is running a secondary 4 wire as his primary on OBD1 ECU for couple months now.
vtec25
Jun 22, 2010 05:27 PM
JFra1357
Jan 6, 2008 11:49 PM
danteisme
Sep 19, 2007 05:32 PM
LostAndFound
18
Jun 25, 2004 10:46 PM
djnikko
Jun 23, 2004 01:24 PM
