Is the AC bracket motor mount necessary?
Old Jun 13, 2005 | 04:18 AM
endless_pain's Avatar
Default Is the AC bracket motor mount necessary?
Hi there
I have a 97 civic with a b series swap. I took the AC system out. My question is, is that bracket and motor mount necessary or can i take it out and just use the 3 mounts left?
TIA
Old Jun 13, 2005 | 03:49 PM
92b18cx's Avatar
Default Re: Is the AC bracket motor mount necessary? (endless_pain)
I drove around with a ripped one for about a year, don't think it will hurt anything,
My buddy ( a mustang guy) would always wonder why hondas have so many mounts, when his 300ft/lb torque V8 only has needs 3,
3 are probably okay...
Old Jun 13, 2005 | 04:00 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
I would suggest leaving the A/C mount in. It's one of the mounts to aid with the motor freely rocking back and forth.
Old Jun 13, 2005 | 04:46 PM
johnmay19's Avatar
Default Re: Is the AC bracket motor mount necessary? (INVALID)
If you didn't need it Honda wouldn't of put it there. end of story.
Old Jun 15, 2005 | 07:53 AM
Default Re: Is the AC bracket motor mount necessary? (johnmay19)
I think that is a inaccurate assumption.
Anyways, that is called an AC bracket, I dont have an Ac anymore, so following your analogy, then I dont need it.
Old Jun 15, 2005 | 07:58 AM
llxzxll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endless_pain &raquo;</TD></TR><TR><TD CLASS="quote">I think that is a inaccurate assumption.
it is an accurate assumption. especially in a EK with a b-swap. i have the same situation where i thought running three mounts was okay since EG's can run with 3 mounts. however, the EG has a stronger driver side mount, which isn't a liquid-filled piece of sh*t like the 96-00 civic's come with. take it from me, i'm still in the process of finding an ac bracket, but you're also going to need the passenger side front tranny bracket as well. without these, you're going to break that POS mount like me and end up paying another 50-60 to fix.
Old Jun 15, 2005 | 08:41 AM
92b16vx's Avatar
Anyways, that is called an AC bracket, I dont have an Ac anymore, so following your analogy, then I dont need it.</TD></TR></TABLE>
Actually no, yours is an inaccurate assumption. It is the bracket that holds the AC compressor, but the mount is a stabilizer mount, it, and it's partner on the other side keeps check on the moment of inertia. I drove around without them for a while, and it sucks, I have poly filled ones now and the difference is amazing. If you are using an aftermarket kit with stronger inserts, you can get away with it because they will control the motor more, but if you are using stock mounts, keep them, as said before they are there for a reason.
Old Jun 15, 2005 | 06:47 PM
johnmay19's Avatar
Yes some call it an A/C bracket yet cars from the factory without A/C have the bracket, if it's an A/C bracket why would that be?
Old Jun 17, 2005 | 02:41 PM
Blitzed's Avatar
YES! Leave the AC mount in. It is always better to have more reinforcement bro.
Old Jun 17, 2005 | 04:16 PM
postman's Avatar
absolutely need to keep bracket!!! even if rubber is torn on mount, helps stabilize position of motor when your raising hell. also 4 bolts that mount the bracket go back in aspecific order if you remove it. other wiase if you need to put it back it will be a bitch to get the bolts the whole way in.
Old Jun 17, 2005 | 05:27 PM
SikofFalln's Avatar
Default Re: Is the AC bracket motor mount necessary? (postman)
You most definitly need that mount. It is a torque mount and it is essential.
Old Jun 17, 2005 | 07:16 PM
Newman's Avatar
New User
If you are using the stock factory mounts, yes, use the A/C bracket lower mount. If you are using any type of aftermarket mounts with solid, strong urethane supporting the motor, then No, you can get away w/out using the lower mounts on that particular side.
Here's a pic that I dug up that I posted a couple of years ago, a driver side replacement mount specifically for the 96-00 Civic chassis:
Old Jul 14, 2005 | 11:21 AM
Default Re: Is the AC bracket motor mount necessary? (Newman)
Cool. Thanks everybody for your inputs. Greatly appreciated.
Old Jul 14, 2005 | 11:25 AM
Mike_C's Avatar
Default Re: Is the AC bracket motor mount necessary? (92b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b18cx &raquo;</TD></TR><TR><TD CLASS="quote">I drove around with a ripped one for about a year, don't think it will hurt anything,
3 are probably okay...</TD></TR></TABLE>
who do you trust to engineer something better? ford or honda?
Old Oct 8, 2022 | 10:48 AM
Jazambr's Avatar
where can I buy them cause I need them too
jdmturbo1127
Jun 13, 2008 03:10 PM
Nicram
10
Feb 6, 2006 02:46 PM
SLeePeR012
Feb 21, 2004 05:59 PM
SLeePeR012
Feb 21, 2004 04:43 PM
B19CivicHB
Sep 23, 2002 09:46 AM
