which is better?
Old Jun 11, 2005 | 09:39 AM
FaceTuned's Avatar
Default which is better?
Old Jun 13, 2005 | 12:17 PM
ZCcivicBOI's Avatar
gggggg mini me will be better because low compression good for junk yard tubo boi...
Old Jun 13, 2005 | 01:38 PM
poundedhatchcrap's Avatar
Default Re: (ZCcivicboy)
Isnt the compression higher on mini me's? Oh well i would say jus keep what u have. The Y8 wont give u enough gain to swap over to it. Just my opinion though.
Old Jun 14, 2005 | 08:19 PM
HatchMo's Avatar
Default Re: (poundedhatchcrap)
but the y8 is total hottness
Old Jun 14, 2005 | 08:25 PM
crxnj's Avatar
I would do the full y8 motor..Seeing how its newer and will be fresher..
Old Jun 14, 2005 | 08:29 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivicboy &raquo;</TD></TR><TR><TD CLASS="quote">gggggg mini me will be better because low compression good for junk yard tubo boi...</TD></TR></TABLE>
Wrong. The mini-me will yield a higher compression. Go with the Y8, newer platform, less miles.
Old Jun 14, 2005 | 08:32 PM
crxnj's Avatar
Default Re: (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong. The mini-me will yield a higher compression. Go with the Y8, newer platform, less miles.</TD></TR></TABLE>
Yeah the d15b2/d16y8 mini-me using a y8 headgasket will be over 10:?:?
Old Jun 14, 2005 | 08:52 PM
Default Re: (Mr.speaker)
If he wasnt planning on going turbo, wouldnt the higher comp be better in his case?
Old Jun 14, 2005 | 09:00 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poundedhatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">If he wasnt planning on going turbo, wouldnt the higher comp be better in his case? </TD></TR></TABLE>
Yes..
But even if he wanted to go turbo he still could..High compression + low boost is fun..
Old Jun 14, 2005 | 09:21 PM
vegaskurt's Avatar
d15 + y8 head will actually put you in the 11's for compression.... Its hard to say if the mini-me or full y8 would yield more power. The y8 bottom end is probably better suited for boost.
Joey Mitchell
Nov 19, 2018 11:53 AM
mp5o
Dec 7, 2005 05:12 AM
cxhb
Jun 12, 2005 08:16 PM
99hatch
Feb 1, 2005 08:36 AM
89 pos
22
Nov 21, 2004 07:03 PM
