Stuttering civic.
Old Jun 9, 2005 | 04:53 PM
JoKarma's Avatar
Default Stuttering civic.
My car doesnt idle smoothly or drive smoothly at all. At idle the car will stutter like its about to die and then come back to a stable rpm. The car throughout 1-2-3 will do the same thing as Im driving. It felt like a fuel problem so I checked my fuel lines. Everythings good there.
Id say its the transmission.. which Ill admit to pushing but I dont really know what it is. Anyone know what else it could be?
Old Jun 9, 2005 | 05:00 PM
Lord Helmet's Avatar
Default Re: Stuttering civic. (JoKarma)
Could be a ignition system problem. Check the voltages from distributor to the spark plug wires to see if it's within factory specs. If it's not back track the parts and check & test each and every parts starting from spark plug, spark plug wires, cap & rotor, ICM aka ignitor, etc....
Old Jun 9, 2005 | 06:18 PM
ham's Avatar
ham
Default Re: Stuttering civic. (Lord Helmet)
sounds like you may have a misfire?
Old Jun 10, 2005 | 04:39 AM
Hurricane's Avatar
Default Re: Stuttering civic. (ham)
Sounds like you need some plugs, cap,rotor and maybe wires.
My Z6 ran like crap just because of a little wear on the ignition components.
Old Jun 10, 2005 | 04:28 PM
JoKarma's Avatar
Default Re: Stuttering civic. (Hurricane)
any good way to diagnose the problem fast?
Old Jun 10, 2005 | 06:12 PM
TsukubaDreams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoKarma &raquo;</TD></TR><TR><TD CLASS="quote">any good way to diagnose the problem fast?</TD></TR></TABLE>
If its just one or two stutters then check your distributor timing, if it feels like you hit your rev limiter and it does it like 5-10 times change your fuel filter. Had the both the probs and each fixed it. Good luck
95_DB7
Aug 31, 2012 09:56 PM
Matt_EH2
Jan 16, 2010 02:54 PM
ex_ricer
Aug 14, 2008 02:14 PM
cilvia
11
Apr 2, 2008 06:00 PM
racin_fool
15
Jul 18, 2006 03:10 PM
