check engine lights?
k guys, im throwing 3 codes, code 10 IAT, code 3 and code 5 (MAP). what would be the problem with the map sensor, its plugged in and working properly.
ok i reset the ecu and im getting no codes, the ABS light will still flash when i connect the jumper for the cel light and it will stay solid when i start the car.
Also the car will start up and will be a little rough, then it will idle smoothly and then it will just suddenly die. Does anyone have any ideas what i should be looking for to fix this problem?
shortlid
Mar 15, 2006 05:04 PM
