throwing strange codes
Old Jul 28, 2004 | 03:39 PM
2000GSRT's Avatar
Default throwing strange codes
I checked my engine codes today and got code 41 (primary o2 heater) and code 10 (Intake Air Temperature sensor). I reset my ECU and took it for a spin.
Now I am not getting code 41 anymore but am still getting code 10.
In addition I am throwing codes 81 (??) and 16 (fuel injectors) on the ABS light. Should I pay any attention to the ABS light or the Check Engine Light??? I didn't know code 81 existed??
I have a '00 GSR turbo with hondata s200. this started happening after I started putting Sunoco 94 octane in my car. Think that gas has anything to do with it?
Modified by 2000GSRT at 10:57 AM 7/29/2004
Old Jul 29, 2004 | 06:57 AM
2000GSRT's Avatar
Default Re: throwing strange codes (2000GSRT)
anyone?
Old Jul 29, 2004 | 07:10 AM
JimBlake's Avatar
Check the wiring for your temperature sensor, then if it's OK replace the sensor.
The ABS light is flashing it's own code. Look up 8-1 & 1-6 in a list of ABS codes, not a list of engine codes.
I've only got the list of ABS codes for '94-'97 Integra. There's a different list for '98 up.
Maybe I'll send Nick my list for the sticky at the top of this BB. Anyone got the list for '98+?
Old Jul 29, 2004 | 08:19 AM
2000GSRT's Avatar
Default Re: throwing strange codes (JimBlake)
Thanks, I looked the codes up for the ABS:
81 = CPU
16 = wheel sensor/pulser for the right rear
damn, something is wierd, why are all of these things suddently happening at once? they seem completely unrelated
Old Aug 2, 2004 | 01:02 PM
2000GSRT's Avatar
well in case anybody cares I found out that the ABS lights usually flashes when you jump the service connector. And as long as the ABS light does not come on while you are driving there is no problem
Old Aug 2, 2004 | 01:05 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">well in case anybody cares I found out that the ABS lights usually flashes when you jump the service connector. And as long as the ABS light does not come on while you are driving there is no problem </TD></TR></TABLE>That's interesting... My '95 doesn't do that. When I jumper the service connector it doesn't flash at all.
You found a list of codes for '98++? Add 'em to my other post about the ABS error codes so other people can search for them.
Old Aug 2, 2004 | 02:11 PM
2000GSRT's Avatar
well im using an OBD1 computer since I have Hondata (which may be the reason the ABS light is flashing)
but if you want me to add the 98+ ABS codes to your other post, post up the link.
THey are in the Helms manual BTW
Old Aug 3, 2004 | 03:39 AM
JimBlake's Avatar
I got the '95 list from my Helm book. I don't have a '98+ book cause I don't own a '98+ Integra...
https://honda-tech.com/zerothread?id=941971
The '95 ECU doesn't have a connection to the ABS, so maybe your 2000 ABS controller is looking for a signal from the ECU that isn't there?
Old Aug 4, 2004 | 11:20 AM
2000GSRT's Avatar
alright, it's a done deal
you may want to post them up as a new topic so people can easily find them
Old Aug 4, 2004 | 05:47 PM
DarkTeg94's Avatar
Hey, how do I check my code for my ABS light on my 94. JimBlake, I know you said you had the list for codes. How do I check it though. I know that there's a connector the is on the right hand side of the dash. The guy I bought it from told me to unhook it and stick a paper clip into the connector. Check to see how many times it blinks and then find out the code for it. Is this right?
Old Aug 4, 2004 | 06:27 PM
tremor86's Avatar
Default Re: throwing strange codes (DarkTeg94)
I keep getting the code 10 also for the IAT. I was getting that code for the o2 sensor too. Whenever I reset my ecu it used to throw different codes. I replaced the IAT and checked for continuity in the harness and all was ok. Im running a genuine skunk2 obd1 p28 on my 96 gsr. I am also running high test gas. WTF?
Old Aug 4, 2004 | 06:45 PM
MyBigNut's Avatar
Default Re: throwing strange codes (tremor86)
In regards to Code 10. Take out the IAT and look at it.. I've seen cases before where the sensor actually gets fried and is the reason for the code. Just replace it if so.
Old Aug 5, 2004 | 04:06 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkTeg94 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, how do I check my code for my ABS light on my 94. JimBlake, I know you said you had the list for codes.</TD></TR></TABLE>I linked it a couple posts up in this thread. I asked a moderator to make it a sticky, so maybe that'll happen. You jumper the same plug as CEL codes.
eg_boi
Aug 4, 2008 01:12 PM
Teamdiesel
Dec 11, 2007 01:12 AM
fanatic
Oct 20, 2004 01:30 PM
2000GSRT
Jul 29, 2004 08:44 AM
2000GSRT
