Bad Map Sensor ?
Old Jan 21, 2012 | 03:24 PM
ShatiaNichols's Avatar
Icon3 Bad Map Sensor ?
I drive a 94' Accord EX and recently my car will drive for a couple of seconds then it will make this disgusting noise, the check engine light will come on, and the car will shut off !! This usually happens when I accelerate or when I brake. I tried a at home diagnostic because I doubt if I can make it to my shop without more trouble and I believe that its the Map Sensor. Could someone tell me if I'm correct or what could possibly be wrong with it ?
Old Jan 21, 2012 | 03:53 PM
GhostAccord's Avatar
Default Re: Bad Map Sensor ?
When you did the "at home" self diagnosis check what code did you get? How many flashes did you get from the check engine light?
Old Jan 21, 2012 | 09:17 PM
Thats what confused me .. my cel didnt flash but my abs light did
Old Jan 22, 2012 | 01:50 PM
Then you are getting an ABS error code. What code are you getting?
Old Jan 23, 2012 | 05:48 PM
Ok so I figured out I was looking at the wrong thing , the CEL code that appeared was 14 -idle air control valve
Old Jan 23, 2012 | 05:50 PM
Could this be what is causing my problems ?
Old Jan 23, 2012 | 05:54 PM
It certainly wouldn't help them.
There is a thread in the FAQ on how to remove and clean the IACV. However it sounds as if yours might just be past the point of cleaning/repair and require replacement. I would still try to clean it and the throttle body to see if maybe something is caught in the ports.
Old Jan 23, 2012 | 07:13 PM
Ok will try that .. Thank you so much
Argenis 2524
Jan 12, 2016 11:10 PM
risenyc
Jul 17, 2013 02:50 AM
chucky86
Oct 13, 2011 02:46 PM
dkray944
Dec 9, 2008 07:53 PM
Touge Tuning
Jun 9, 2005 03:20 PM
