blown motor
Old Jun 8, 2005 | 09:32 PM
StraightCivic's Avatar
Default blown motor
i was riding with my friend with a 95 honda civic with a 1.5 l sohc auto. and we were riding along we heard something that sounded like an exhaust leak and then we heard bangin and it backfired and he car shut off on the highway ( we were driving normal at 65 ) and then he pulled over and he poped the hood white smoke was rollin out of the block. What did he do? He doesnt have the internet so i gotta help him out. I think its a blown motor. if so what u think he should get? its already decided for the 5 speed swap. and hes thinking b16a2 what u guys think?
Old Jun 8, 2005 | 09:36 PM
bokals's Avatar
Default Re: blown motor (StraightCivic)
b16a2 eeeeh...
if he has the money go with the b18c5
H22a 4 life
Old Jun 8, 2005 | 09:41 PM
Default Re: blown motor (core3200tm)
he aint got much money and **** but im trying to talk him into droppin the h22 but hes worried bout the timing belt/ blow motor. we know a lot of ppl who has broke a timing belt and blew there motor cuz of it.
Old Jun 8, 2005 | 09:47 PM
ZedEx's Avatar
Perhaps the timing belt did break... There is a chance that the motor is salvagable. Pending on what RPM you were at when the belt broke.
If it's just a D15, it isn't that expensive to just get the same motor... One or Two hundred would do the trick more than likely.
I'd say go with that for now, and worry about the other motor swap later. If he doesn't have the money for a swap... Why try and do one? You'll just end up with a bigger problem, that's not worth solving.
Keep it simple and stock until you have enough money to do it right.
Just my opinion.
Old Jun 9, 2005 | 04:05 PM
Default Re: (ZedEx)
the belt didnt break i seen the belt to the crank ( timing bellt ) and its tight plus he did get it started the motor banged back and forth and you could hear **** bangin around and after like 2 min it shut off. But see his dad offered to co sign for him a toyota truck. then he called his dad back saying he wanted an new si and he wud get better gas mileage and itys cheaper so i think him and his dad are going when we get back from the beach to get a car.
Old Jun 9, 2005 | 06:09 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic &raquo;</TD></TR><TR><TD CLASS="quote">i was riding with my friend with a 95 honda civic with a 1.5 l sohc auto. and we were riding along we heard something that sounded like an exhaust leak and then we heard bangin and it backfired and he car shut off on the highway ( we were driving normal at 65 ) and then he pulled over and he poped the hood white smoke was rollin out of the block. What did he do?</TD></TR></TABLE>
Pull the radiator cap off and see if there's any coolant in there. That sounds a whole lot like what happened when my blew up my '84 BMW. Car had a coolant leak that I didn't now about and ended up seizing the block.
When he was driving was it like a loud puttering noise and then the car jerked, lots of white smoke behind you?
Old Jun 9, 2005 | 06:11 PM
sohcvtec1995's Avatar
If he aint got that much money tell him go d16z6.
Old Jun 20, 2005 | 01:25 AM
_Cyclone_'s Avatar
That's what happens to engines when you do too much of this:
Old Jun 20, 2005 | 02:46 PM
Aespooncivic's Avatar
i did the same thing doin 70 on the highway.. i took the motor apart and found that i snapped a rod and blew a hole in the block about the size of 2 of my fingers
Old Jun 20, 2005 | 02:49 PM
JDM-EJ1's Avatar
Default Re: blown motor (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">If he aint got that much money tell him go d16z6.</TD></TR></TABLE>
Hell yeah, that's a good little motor.
Old Jun 20, 2005 | 02:57 PM
Greasemonkey's Avatar
LS.. if you aint' got the doe..
Old Jun 20, 2005 | 04:17 PM
TheNasty0ne's Avatar
Default Re: (Greasemonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey &raquo;</TD></TR><TR><TD CLASS="quote">LS.. if you aint' got the doe..</TD></TR></TABLE>
why spend 600 on a single cam when you can get a dual cam for 800
hDooshDooshCvC
Feb 11, 2009 05:43 PM
hybrids2k
Jan 26, 2009 12:38 PM
80 dolla crx hf
Other Make Vehicles
Jul 5, 2008 07:24 AM
KENLUDE97
Jun 3, 2003 12:16 PM
shockincivic
Mar 23, 2003 09:17 PM
