Leaking: steering wheel bushing?
Old Jun 8, 2005 | 01:28 PM
yh23's Avatar
Default Leaking: steering wheel bushing?
was removing steering wheel control from the front assembly. looks like I punctured it and black oozey grease came out. is that gonna be a problem or will it be fine?
should I replace or can I just leave it?
Old Jun 9, 2005 | 04:33 PM
yh23's Avatar
Default Re: Leaking: steering wheel bushing? (yh23)
ttt
anyone??
Old Jun 9, 2005 | 05:16 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 &raquo;</TD></TR><TR><TD CLASS="quote">was removing steering wheel control from the front assembly. looks like I punctured it and black oozey grease came out. is that gonna be a problem or will it be fine?
should I replace or can I just leave it?</TD></TR></TABLE>
Are you talking about the rack and pinion rubber boots?
Old Jun 9, 2005 | 07:20 PM
yh23's Avatar
Default Re: Leaking: steering wheel bushing? (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about the rack and pinion rubber boots? </TD></TR></TABLE>
I believe it is the rack+pinion rubber boots.
steering connection to the HUB.
what to do?
thanks!
Old Jun 9, 2005 | 08:55 PM
yh23's Avatar
bump...anyone?
Old Jun 9, 2005 | 09:17 PM
what to do?
thanks!
Inner or outter boots? The one next to the steering knuckle or the rack and pinion itself? If it's the one on the steering knuckle then that's called a tie rod. Which is easy to fix.
SETI20
12
Nov 5, 2007 02:25 AM
rachonda
Jul 5, 2007 06:54 PM
cbmprelude
Sep 9, 2005 08:13 PM
Used2beAb16
Jun 27, 2005 05:25 AM
SIR Spooner
Mar 8, 2004 07:50 PM
