Leaking: steering wheel bushing?
was removing steering wheel control from the front assembly. looks like I punctured it and black oozey grease came out. is that gonna be a problem or will it be fine?
should I replace or can I just leave it?
Re: Leaking: steering wheel bushing? (yh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">was removing steering wheel control from the front assembly. looks like I punctured it and black oozey grease came out. is that gonna be a problem or will it be fine?
should I replace or can I just leave it?</TD></TR></TABLE>
Are you talking about the rack and pinion rubber boots?
Re: Leaking: steering wheel bushing? (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">Are you talking about the rack and pinion rubber boots? </TD></TR></TABLE>
I believe it is the rack+pinion rubber boots.
steering connection to the HUB.
what to do?
thanks!
what to do?
thanks!
what to do?
thanks!
Inner or outter boots? The one next to the steering knuckle or the rack and pinion itself? If it's the one on the steering knuckle then that's called a tie rod. Which is easy to fix.
what to do?
thanks!
rachonda
07-05-2007 06:54 PM
cbmprelude
09-09-2005 08:13 PM
SIR Spooner
03-08-2004 07:50 PM
