I lost steering while driving!!!!!!!!!!!!!!!!!!
Old 07-05-2007, 05:55 PM
rachonda's Avatar
Default I lost steering while driving!!!!!!!!!!!!!!!!!!
What could make you lose steering while you tried to turn? When i jumped out the passinger side wheel was was turned all the way in as if i turned the steering wheel to make a left. It made a pop right before it did this.
Old 07-05-2007, 06:01 PM
mckrank313's Avatar
Default Re: I lost steering while driving!!!!!!!!!!!!!!!!!! (rachonda)
check your lower control arm, shock, steering rack, if the axle got messed up someone how that could cause a problem.
the pop sounds like something came disconnected or the axle is broken, pops are a sign that somehthing with the susspension is messed up causing this problem to happen.
Old 07-05-2007, 06:04 PM
x justin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rachonda &raquo;</TD></TR><TR><TD CLASS="quote">...When i jumped out...</TD></TR></TABLE>
Old 07-05-2007, 06:05 PM
rachonda's Avatar
Default Re: I lost steering while driving!!!!!!!!!!!!!!!!!! (mckrank313)
its either gotta be the lca or the steering rack. cause i could move the wheel back and fourth( meaning left to right) I had to get the car off the road so i had to turn the wheel so it would move
Old 07-05-2007, 06:07 PM
95civiccpdx's Avatar
check tie rod ends!!!
rachonda's Avatar
............and what would make these fail?
Old 07-05-2007, 06:09 PM
RiceKillinSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rachonda &raquo;</TD></TR><TR><TD CLASS="quote">When i jumped out the passenger side wheel was was turned all the way in as if i turned the steering wheel to make a left. It made a pop right before it did this.</TD></TR></TABLE>
Was your steering wheel straight? If your passenger wheel was turning left while your steering wheel was straight then it sounds like the tie rod end or the rack and pinion broke.
Old 07-05-2007, 06:12 PM
rachonda's Avatar
Default Re: I lost steering while driving!!!!!!!!!!!!!!!!!! (RiceKillinSI)
steering rack, lca, tie rod ends and rack and pinoin all can make the car lose steering.........
Old 07-05-2007, 06:54 PM
MatterMatt's Avatar
Broken balljoints could also, but you would have some fender damage too (that side of the cars suspension would kind of collapse). Wear and tear on older cars, especially if the tie rod or ball joint had open boots that made them dry out. If your car is lowered pretty far with the suspension geometry out of whack (camber, toe, maybe even caster) it would put more stress on bushings, axles, balljoints, control arms, etc. That, some aggressive driving, a few pot holes and UH OH! Broken suspension parts!
94BlueGSR
12-02-2006 10:07 AM
buzlink
18
11-07-2006 07:04 AM
Padronis
07-28-2003 09:00 PM
jabroni95gsr
02-13-2003 04:12 AM
Quick Reply: I lost steering while driving!!!!!!!!!!!!!!!!!!
