Engine starts-then stalls
Old Jun 6, 2005 | 07:01 PM
mackdyme's Avatar
Default Engine starts-then stalls
Well, It goes a little something like this...
I own a 94 Del Sol Vtec, I've had it for a couple years and I've recently been having some problems. I can start it up just fine but after about 3 to five minutes of idling (normal idle, high at first, then low), all the gauges (all stock, no aftermarket gauges) shut down, and a few seconds later the engine cuts off. I can restart it, but the exact same thing happens again. I've replaced the cap, rotor and plugs and I also replaced the alternator recently. At first I thought the voltage regulator might have gone bad, but then I found out that the voltage regulator and the alternator are integrated. I've read through the topics but I haven't come across anything quite like this. If anyone has any ideas/suggestions/etc I would greatly appreciate it. Thanks.
Old Jun 6, 2005 | 07:22 PM
b18c5 EG's Avatar
ive been searching for awile because i have a similar problem and found nothing! somebody help!
Old Jun 7, 2005 | 04:26 AM
Hurricane's Avatar
Default Re: (94_Del Sol)
Does anybody know if a main relay can fail in a weird way and cause their problem?
pony tech
May 27, 2009 08:23 PM
92integracer
Oct 8, 2008 09:19 PM
stocker2shocker91
Mar 22, 2008 03:52 PM
redricer
Jul 25, 2007 07:19 AM
Lee_Delso
11
Nov 3, 2004 01:11 PM
