Information on turbocharging a D15
I sold my buddy a '91 DX hatch with the D15. He wants to build the engine and add a turbocharger @ around 15 PSI boost.
I'm not asking for opinions on what anyone else would do to the car or with the engine, I need information on this subject.
He wants to know about what compression pistons he needs an what - not. Any other suggestions to improve the engine? Does anyone know of a good tubo kit that would do what he wants. This is to be a test & tune, play around with drag car.
Thanks
Thanks
15 psi on a d15, atleast from what ive read, would be disastrous without a built bottom end. someone with more experience on the matter should chime in on why this may or may not be a bad idea though. from what ive read, i think the d15 rods are some of the smallest, least beefy rods you can find in any d series. this does not bode well for turboing. and as far as i know, there is not a turbo kit you can just buy. you would have to build one yourself. on the plus side though, d-series engines are cheap, so if you blow it up, its only like $400 to get a new one. good luck though.
Do a mpfi swap! Then get a D16a6 or a ZC and boost it!!! The stock platform will handle up to 10psi reliably. Why build a D15?(unless you do a mini-me then you still need MPFI). That much effort and money why not start off with a good platform? Just my opinion.
Thanks for the info.....Yeah, as I said, he plans on building the engine...top and bottom as much as possible. I agree with you sanimalp, but it's not my deal...he was going to put in a 1.6 dohc or 1.8, but figured it to be cheaper to beef up the 1.5 and force alot of air into it. I did find a few turbo kits for the 1.5 on EBAY and another site that was WAY expensive, but came with alot of beefy go fast parts. The kits I saw on EBAY were around $300-400, and didn't come with the real goodies. I think if he goes the cheap way, he won't get what he really wants. If he goes the $ 6500 turbo kit way.....well, he doesn't have that kind of money right now to put into it.
Any more info is appreciated and thanks again to those that replied.
RW
RW
D-series.org-Forced Induction Forum
why does everyone think that psi is the limitng factor for how much power a stock block can handle? a small turbo @15 psi on a stock d motor is grey area but doable. a big snail pushing less psi could break the motor, but i would honestly say the limit is in the tuner's abilites
if you want to run that much psi....get vitara pistons.....they are cheap and a great improvement......also if you get a d16 use zc rods or d16a1 rods since they are a little stronger and depending on us set up just get good tuning and fuel......
94_civic_guy
May 22, 2003 12:50 PM
