Always on brake light
Old Jun 2, 2005 | 11:23 PM
simbey1982's Avatar
Default Always on brake light
I was just inquiring as to what you all may think....1992 Accord EX
I have a brake light that is on all the time...at varying degrees of brightness....also the ABS light will come on at random times...
YES i have checked the fluid, Brakes work great, ABS works (Checked it on some wet pavement), checked two wires coming from the brake fluid resivoir....
My only thought is perhaps the fluid level indicator electrics are malfunctioning and a new cap is in order.....any other thoughts??
Thanks
Cory
Old Jun 3, 2005 | 06:43 AM
deserthonda's Avatar
you are on the right track it could be the master cylindeer reservoir switch , jump wires if lite goes off that's it..,also make sure e-brake is not hanging up on you,,..... lever is all the way down
Old Jun 3, 2005 | 07:37 AM
simbey1982's Avatar
Thanks i will try that....yeah brake light gets brighter when the e brake is on....any other ideas??
Old Jun 3, 2005 | 09:29 AM
simbey1982's Avatar
tried jumping the wires...brake light came on brighter
Old Jun 3, 2005 | 01:08 PM
ex_techniques206's Avatar
hey, my friend had a 91 accord that said his e-brake had always come on, usually on and off, and that it would come on when he took sharp turns, and it gets brighter when you actually pull the e-brakes....he said his brakes were working real good, but took it to the shop, and found out that his brakes at the back were dead, so im pretty sure its your brakes
Old Jun 3, 2005 | 04:37 PM
simbey1982's Avatar
hmm...what about the brakes being "dead" makes the light come on???
Old Jun 3, 2005 | 06:05 PM
philadd's Avatar
Default Re: (simbey1982)
I had a similar problem in my car. I thoroughly cleaned the wire connectors inside the fluid resevoir, and haven't had the problem since.
Old Jun 4, 2005 | 12:10 AM
v-technician's Avatar
Default Re: (philadd)
If your brake light is on all the time the most obvious thing would be your brake switch. No need to xplain. Or do you mean your ( ! ) light on gauges? Try checking terminals or what not on the m.cyl resivoir sensor, or perhaps your slave cyl is playing up.
Old Jun 7, 2005 | 10:12 AM
simbey1982's Avatar
Thanks everyone for your replies, i will post when i fix the issue.......
misterix
Nov 22, 2010 03:19 AM
dubzxallxstar
May 25, 2010 06:03 PM
mikester_91
Jan 18, 2005 01:14 PM
FK00GSR
Nov 7, 2003 12:32 PM
WeSsCyDeR
Oct 4, 2002 09:24 AM
