Brake Light.. ABS light..
Old Oct 3, 2002 | 07:17 PM
WeSsCyDeR's Avatar
New User
Default Brake Light.. ABS light..
Help my brake light and abs light randomly turn on and off when I start my engine and after 10 mins its usually ok.. does anyone else have this problem?
WeS
[Modified by WeSsCyDeR, 8:18 PM 10/3/2002]
Old Oct 3, 2002 | 08:45 PM
prelude1897's Avatar
Default Re: Brake Light.. ABS light.. (WeSsCyDeR)
Nope...Check your brake fluid and make sure you have enough, also check your brake pads to see if they're still good
Old Oct 4, 2002 | 09:24 AM
lizrdboy's Avatar
Default Re: Brake Light.. ABS light.. (prelude1897)
check the connection to the brake level fluid sensor - two wires coming off the master cylinder cap. make sure there are no shorts in the wires or they weren't taken off and connected together..
low brake fluid level may cause the floater sensor to bob up and down as well, causing the lights to come on and off periodically.
dubzxallxstar
May 25, 2010 06:03 PM
supermotothud
Nov 10, 2008 04:09 PM
dt4life
Nov 3, 2004 08:59 AM
sushib01
Aug 30, 2004 03:43 PM
FK00GSR
Nov 7, 2003 12:32 PM
