ok rebuiliding a transmission that hesitates to go into gear... not clutch
Old Jun 1, 2005 | 05:52 PM
gaydm.accord's Avatar
Default ok rebuiliding a transmission that hesitates to go into gear... not clutch
ok well im pretty good at tearing things apart. what my question is what could be the problem if my tranny hesitates to go into gear. from 1 through reverse it happens in all gears. i would step on the clutch and nudge on the shifter but it wont budge unless i put a little bit of force on it. speed-shifting is not a possibility with this transmission because of the hesitation/lag/delay and its not the clutch, the transmission fluid, nor is it the master or slave cylinder running low or failing.
the 2-3 synchro is already bad so im looking into replacing that as well as all the cheap seals and stuff. any other recommendations when i rebuild this tranny would be greatly appreciated.
Old Jun 1, 2005 | 08:40 PM
bump
Old Jun 2, 2005 | 01:58 AM
i know someone knows something
Old Jun 5, 2005 | 09:34 PM
up
EKcpe00
10
Jan 24, 2011 05:51 PM
withemptyeyes
Sep 18, 2007 05:47 PM
solRNY
Jul 25, 2004 11:17 AM
mchuang
Mar 9, 2004 05:14 AM
tilt
Oct 7, 2002 01:22 PM
