Impact Wrench for suspension bolts
Old Jun 1, 2005 | 04:43 PM
94CoupeEJ1's Avatar
Default Impact Wrench for suspension bolts
I have a wimpy impact wrench that came with my compressor that isn't good for much. I'm guessing it's in the 240 ft lbs range or less. How much power do I need for suspension bolts? Walmart has good prices on a 380 ft lb CH wrench. Is that adequate or do I need to move up to the 500 at Home Depot? Thanks
Old Jun 1, 2005 | 04:45 PM
Kyles ej1's Avatar
Default Re: Impact Wrench for suspension bolts (94CoupeEJ1)
****, i used my guns and they were virgins too
Old Jun 1, 2005 | 04:55 PM
komat's Avatar
Default Re: Impact Wrench for suspension bolts (93ejay1)
invest in something with like 750lb or more
worth every penny
if you trying to losen your rear lca bolt. get another bolt b4 you do!
theres a good chance its going to break if you cant do it with hand tools with a cheater bar
Old Jun 1, 2005 | 05:03 PM
funvtec's Avatar
ir 2135ti or ir 2131 or or 232tgsl or ir 231
Old Jun 1, 2005 | 05:50 PM
94CoupeEJ1's Avatar
Default Re: Impact Wrench for suspension bolts (komat)
Anybody else use something less? Not going to use this much so don't want to spend much? Thanks
Old Jun 1, 2005 | 06:06 PM
saxqtzk's Avatar
If it is the LCA bolts, be careful with an impact wrench...
did is how mine turned out, granted 4 out of 6 bolts were fine and came out without using a impact wrench.
http://www.we-todd-did-racing....D.jpg
Basically both ends broke off.
Old Jun 1, 2005 | 06:08 PM
funvtec's Avatar
Default Re: Impact Wrench for suspension bolts (saxqtzk)
all mine busted too, its common they break and using an impact on them is better than doing it by hand
Old Jun 1, 2005 | 06:11 PM
93Civac's Avatar
Spray the crap out of the bolts with some penetrating oil too, The one you have may work but you may have to step up to a 500 to 750.
Old Jun 1, 2005 | 06:36 PM
saxqtzk's Avatar
Default Re: Impact Wrench for suspension bolts (funvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funvtec &raquo;</TD></TR><TR><TD CLASS="quote">all mine busted too, its common they break and using an impact on them is better than doing it by hand</TD></TR></TABLE>
Agree! I was lucky some of them could still be turned by hand.
Old Jun 1, 2005 | 06:47 PM
mp5o's Avatar
Mine came off fine... Pb blaster, some patience, and man power worked for me.
Old Jun 1, 2005 | 06:53 PM
mrlegoman's Avatar
Default Re: Impact Wrench for suspension bolts (mp5o)
LCA bolts suck
I bought my impact wrench from Harbor Freight for like 50$ and it seems to work fine for as little as I use it.
Also, I really hope you meant for taking OFF your bolts and not for putting them on
Old Jun 1, 2005 | 08:55 PM
hatchi's Avatar
why not use a 1/2 inch breaker bar then use the gun once its loosened
Old Jun 1, 2005 | 08:59 PM
EK k kay's Avatar
Default Re: Impact Wrench for suspension bolts (hatchi)
Put some muscle to it. I'm a very small guy and I can manage to undo and re-install the suspension all by myself.
Old Jun 2, 2005 | 12:56 AM
funvtec's Avatar
Default Re: Impact Wrench for suspension bolts (chowmien)
i forgot to add if you are doing the lca bolts upon reassembly USE ANTISEIZE!
Old Jun 2, 2005 | 01:23 AM
94_HATCH's Avatar
We use craftsman impact guns at my buddies house when i bought my new suspension. All bolts came off fine without any trouble. Dont know the power setting though
Old Jun 2, 2005 | 04:00 AM
EKB18BPR3's Avatar
i work for a nissan dealer and we never use impact gun on suspension bolts because they will break off. of course we use the snap-on 800 plus torque gun. we normally spray with aero-kroil and use the wrench. but thats us because dealers have different standards then mom and pop shops and people who work on their own cars.
Old Jun 2, 2005 | 08:28 AM
notfastenough's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp5o &raquo;</TD></TR><TR><TD CLASS="quote">Mine came off fine... Pb blaster, some patience, and man power worked for me.</TD></TR></TABLE>
As long as I have used pb blaster, this method has not let me down. Use 6pt sockets or wrenches and blaster and you have made the job easy and almost foolproof
Old Jun 2, 2005 | 04:21 PM
94CoupeEJ1's Avatar
I found the information I wanted today at work. The important number is the power the wrench has in reverse. The wrench needs to have 500 ft lbs in reverse.
Actually I just want one for the jobs when one is needed loosening troublesome nuts and my existing gun is too weak. I did my rear LCA's last summer and had no trouble with a regular wrench. The PO did me good on them. Now I'm looking at replacing my front shocks and want a gun handy in case I need it. I haven't even looked at the manual to see what is involved. I'll do that now. The shocks come tomorrow. Thanks
Old Jun 2, 2005 | 05:53 PM
saxqtzk's Avatar
well, for mine the front was a breeze... the only bolt that gave me any trouble was the bolt holding the end of the shock on the fork. It eventually came off with some good old cursing at it and begging it to come off. Other than that everything was a piece of cake....
The rear on the other hand...
Also, i happened to try to use a 240ft/lb wrench today on my trailing arm and it actually got out most of the bolts, the only bolt it didn't manage to get was the one holding the upper control arm to the lower control arm. Switched over to a 550 and it came right off.
Old Jun 2, 2005 | 06:04 PM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">why not use a 1/2 inch breaker bar then use the gun once its loosened</TD></TR></TABLE>
Because (sometimes) this is what happens if the bolt is really stuck: http://www.we-todd-did-racing....D.jpg
DC4_MADMAN
Suspension & Brakes
Jun 8, 2005 08:34 AM
MI4$DC5
19
Apr 2, 2005 09:10 AM
PLRacer
Jun 11, 2004 06:30 AM
Chris_
15
Jun 20, 2002 01:17 PM
accord4banger
Oct 10, 2001 07:12 AM
