fOG LIGHT QUESTION?
I got a set of foglight and i tested it by using the car battery and it doesnt light up.
and I heard dat battery power doesnt work with the foglight, but some how u need to do some different wiring to different power source in the car beside the battery.
Any one have an opinion to share because I would like to know how to wire the foglight to make it work.
its cause you didnt wire it to the switch to turn it on.
no really. I think that it goes into the fuse box underneath the dash and that
coverts it to like 12v or some **** like that...GL
you need to wire the fogs to a switch. then you can wire the power to the battery, using an inline fuse, also wire a ground. that's all i did. even have a nice little switch that is black and has a little light...about as factory as i could get.
inline fuse holder:
http://www.radioshack.com/prod...-1238
switch(similiar to mine):
http://www.radioshack.com/prod...2D730
don't forget the clamps/connectors and the other little things.
good luck.
inline fuse holder:
good luck.
EliteCivicX
Apr 10, 2005 06:07 PM
Halo
May 11, 2003 06:44 PM
