Battery Cut off Switch
So I have everything wired up minus the wire from the alternator to the battery.. Moroso instruction state i can use 10g wire..How exactly am I running this wire? I have searched and for nothing.. Do I run it from the fuse box or what!? Please help! Thanks!
Re: Battery Cut off Switch
alternator to the + side battery with maby a inline fuse then + side of battery to one terminal on the cut off switch.fuse box power should be coming from the other side of the cut off switch terminal along with starter power..hope that helps
Good topic. I know it comes up every year. But Ive been confused, and needing to wire mine up for years. LOL. I think Im starting to understand...
But just to clarify:
Coming off of the + battery terminal, two wires. One goes to the switch, and the other goes to the alternator.
Coming off of the opposite post on the switch, two wires. One goes to the starter, and the other goes to the fuse box.
Correct?
Correct?
Can't you just run the other switch side to the fuse box where the starter wire goes? Instead of to starter then another wire from starter to fuse bo
Battery to alt
Battery to 1 side of cutoff
Starter to other side of cutoff
Fuse/switchpanel to same side as starter on cutoff
Not that hard folks
Not that hard folks
i just ran a larger wire size from the cut off to the front of the car and tee it off with a little smaller gauge one to the fuse box (my case switch panel) and other directly to the starter. not that hard ..
notnic3
06-12-2017 11:26 AM
