Timing adjustment
Old May 31, 2005 | 10:55 AM
jztt's Avatar
Default Timing adjustment
Can someone tell me where is the connector located that you short to adjust timing. I have a d16z6 95 civic and I have never set the timing before. I need to know where it is located.
Thanks
Old May 31, 2005 | 10:58 AM
EJ1 wilcox's Avatar
Default Re: Timing adjustment (jztt)
On the passenger's side right below the glove box, reach up in there and you will find a connector with 2 pins, just put a paper clip in there to set the timing.
Old May 31, 2005 | 10:59 AM
IHateJDM's Avatar
its by the floorboard on the passenger's side, right above the ecu. Its the only 2 wire connector there.
Old May 31, 2005 | 11:01 AM
jztt's Avatar
Thanks. I love this forum. You guys are quick.
Old May 31, 2005 | 12:14 PM
jztt's Avatar
Default Re: (jztt)
hey guys is that a blue connector with a black and brown wire? Is it located all the way on the right side under the dash on the right side of the glove box?
Old May 31, 2005 | 12:22 PM
UserX826's Avatar
is that totally necessary? my timing was adjusted and we never shorted that...
mine is obd2 though.....
Old May 31, 2005 | 12:31 PM
IHateJDM's Avatar
Default Re: (jztt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jztt &raquo;</TD></TR><TR><TD CLASS="quote">hey guys is that a blue connector with a black and brown wire? Is it located all the way on the right side under the dash on the right side of the glove box?</TD></TR></TABLE>
yep, that's it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UserX826 &raquo;</TD></TR><TR><TD CLASS="quote">is that totally necessary? my timing was adjusted and we never shorted that...
jumping that connection forces the ecu into closed loop operation, meaning that it does not alter the fuel or ignition maps in any way. I wouldn't set my timing without jumping it first.
Old May 31, 2005 | 12:55 PM
jztt's Avatar
Thank you "IhateJDM" I really appreciate it. Your the man.
thatbluecrx
Feb 27, 2005 10:15 AM
type Gendy
May 18, 2003 02:53 PM
fe519
Nov 23, 2002 03:55 PM
martilafox
Jan 1, 2002 10:26 PM
LudeSi-93
Jun 18, 2001 01:07 PM
