Civic Ek 96 With F20b engine, Ecu problem
Hi I Have an F20b Engine year 2000 with the OBD2 PCB Ecu, I bough a conversion OBD2 to OBD1 harness with a reprogrammed P28 Ecu. But I get a Check Engine code #14 (idle air control valve ) and my rpm is jumping on idle from 1000 to 2500, Anyone know how to fix this??? Thanks
take the idle air control valve off and clean it... also try and unplug the iacv and see if the idle surge stops... iacv might be bad.. tehy are easy to come by
MonkeyMagic
May 4, 2008 02:30 PM
juka
Oct 18, 2004 06:36 AM
