S LIGHT BLINKING!!!!!!!
Old May 24, 2005 | 01:41 PM
jsteezy1290's Avatar
Default S LIGHT BLINKING!!!!!!!
MAYBE YOU GUYS CAN HELP ME???
HERES MY ORINGINAL POSTS
ok guys i did the search before posting so dont come down to hard..
i have a 91 accord ex auto. the s light is blinking and the car is shifting like crap. the speedometer works fine. the thread i found says something about a wire with blue tape on it and jumping it.. anyways i didnt really get how to jump it or with what wires to jump them too. also i went to a local salvage yard and swaped tcu and still no luck i can send pics of the mess i have under the carpet. there is also two wires that go in a plug that doesnt hook up to anything so i dont know if thats a problem so any help would be great
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: S LIGHT BLINKING!!!!!!!! (jsteezy1290) « » 11:00 PM 5/19/2005 Reply Edit
bump!!!!!
Accord95Lxxx
(trial)
Offline
22 posts [100%]
Jacksonville FL
5-10-2005
« « » 2:06 AM 5/20/2005 Reply Edit
generally on an accord of that age, the S blinks because it is telling you your car is S-LOW hehe just kidding, its probably a speed sensor
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (Accord95Lxxx) « » 2:41 AM 5/20/2005 Reply Edit
please only real posts, its a serious matter to me thanks
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (jsteezy1290) « » 2:38 PM 5/20/2005 Reply Edit
bump!!!!! come on ive seen respond to this kind of questions
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: (jsteezy1290) « » 3:36 PM 5/20/2005 Reply Edit
The 'S' light is kinda like a check-engine light, but for your tranny. Look around for instructions for pulling CEL error codes, for your year (not the same as my '98). Post back with the codes.
If you jumper a connection & watch the light blinking, then your 'S' light will blink its own code while the CEL is blinking its code.
If you simply peel back the carpet & watch the flashing LED, then you have to find both the engine ECM & the transmission TCM & watch both their flashing LEDs.
I know you found instructions about jumpering, but I sorta thought that setup was newer than 1991. Make sure you look for the proper year.
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
TECHNICAL(?) quote of the week/month...
Quote, originally posted by ?? »
Right on look at semi's and tractor trailors. The majority of their tq is created by the transmission.
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (JimBlake) « » 10:57 PM 5/20/2005 Reply Edit
HOW DO YOU JUMP THE WIRES??? AND CHECK THE CODES??? HELP PLEASE ANYONE THANKS
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: (jsteezy1290) « » 11:00 PM 5/20/2005 Reply Edit
If '91 has the wire-jumper thing...
Find the proper wire (this is the part I can't really help since I don't have a '91).
Bend a paperclip into a 'U' shape, put it into the plug.
Turn ignition on.
Watch the CEL & 'S' lights flashing.
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
deserthonda
Offline
369 posts [98%]
AZ
4-7-2005
« « » 7:36 AM 5/21/2005 Reply Edit
under the dash on passenger kick panel there is a blue plug that does not plug anywhere it has 2 wires it is on rt side of blower motor , find it and do as JIMBLAKE said connect the 2 pins together and read the blinks ,,, post here we can detect code
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (deserthonda) « » 3:21 PM 5/21/2005 Reply Edit
ok i will i was wondering where that plug went.. so ill take a paper clip and connect the two and read the codes for yall.
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (jsteezy1290) « » 10:39 PM 5/22/2005 Reply Edit
ok heres the codes
cel light codes is 5 blinks
tranny codes is 1 quick blink, pause, 1 quick blink followed by 1 regular blink.
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (jsteezy1290) « » 2:19 AM 5/23/2005 Reply Edit
bump!!!!!!
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: S LIGHT BLINKING!!!!!!!! (jsteezy1290) « » 4:09 PM 5/23/2005 Reply Edit
bump!!!!!!!!!!!!
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: S LIGHT BLINKING!!!!!!!! (jsteezy1290) « » 4:34 PM 5/23/2005 Reply Edit
CEL code 5 is manifold pressure is higher or lower than expected. But that's from my '98 Helm book, I didn't think '91 had that code. Who's got a '91 Helm book?
I don't know about your tranny codes, they don't match my list, but who knows what's different '91 vs. '98??
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: S LIGHT BLINKING!!!!!!!! (JimBlake) « » 7:02 PM 5/23/2005 Reply Edit
thanks manifold could be my exhaust i def.. need a new one.
bump!!!! on the tranny codes
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: S LIGHT BLINKING!!!!!!!! (jsteezy1290) « » 8:35 PM 5/23/2005 Reply Edit
It would be the intake manifold. For my '98, that means the MAP sensor reading is inconsistent with all the other sensors & the operating conditions of the engine. I didn't think '91 had that much software cross-checking all the sensors against each other. That kinda stuff is why OBD-2 cars have so many sensors. Redundant measurements.
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: S LIGHT BLINKING!!!!!!!! (JimBlake) « » 9:27 PM 5/23/2005 Reply Edit
bump on the tranny codes!!!!!
Chiovnidca
Online
4771 posts [100%]
Honda Tech Member
4-25-2002
« Re: (jsteezy1290) « » 10:36 PM 5/23/2005 Reply Edit
Quote, originally posted by jsteezy1290 »
That doesn't make sense. Can you check the code again? Remember that between codes there is a long pause, about 3 seconds. Start after that. There may be more than one code. They will keep repeating.
My project car. (lots of pics)
https://honda-tech.com/zerothread?id=1010778
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (Chiovnidca) « » 10:46 PM 5/23/2005 Reply Edit
there is one short blink. then after a sec or two there is another short blink followed by a long blink
Chiovnidca
Online
4771 posts [100%]
Honda Tech Member
4-25-2002
« Re: (jsteezy1290) « » 11:59 PM 5/23/2005 Reply Edit
If your sure about that, your TCU must be f-ed up. Long blinks always come first.
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (Chiovnidca) « » 12:49 AM 5/24/2005 Reply Edit
not if theres two codes
bump!!!!!!!!!
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: (jsteezy1290) « » 12:49 PM 5/24/2005 Reply Edit
The way you're describing it, the first code is one short blink. Tranny code 1 (in 1998...!) occurs together with CEL code 70, it means the lock-up clutch can't engage/disengage & it's stuck in 4th. I don't know what it mean in 1991.
But then you say it's a short blink followed by a long one. Is there another long pause between these 2? If so, then you've got 3 codes. Code 1; repeated code 1; & code 10. My list doesn't have any tranny code 10.
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (JimBlake) « » 8:55 PM 5/24/2005 Reply Edit
yea i found a site that told me that code 1 is the lock up control selonoid, which doesnt tell me how to fix it. and the second one is the ect i think..
JimBlake
Online
5882 posts [100%]
NE Ohio
1-16-2003
« Re: (jsteezy1290) « » 9:42 PM 5/24/2005 Reply Edit
I bet 'How-to-fix-it' would be pretty specific to your year. Gotta get your hands on a Helm manual.
Generally, once you have the code, you still have some diagnosis for exactly which component is broken. As far as the TCM throwing error codes, it can't tell the difference between a bad control solenoid or disconnected wiring.
JimBlake
'95 GS-R 4door SOLD
'98 & '03 Accords
'01 Saab 9³
'05 Saab 9²x
jsteezy1290
Online
275 posts [100%]
springfield ohio
1-31-2004
« Re: (JimBlake) « » 10:39 PM 5/24/2005 Reply Edit
IVE SEEN POSTS FOR THIS TOPIC, I KNOW SOME PEOPLE GOT INFO ON THIS...
HELP ME OUT SOMEONE
Redcoupe
Jan 12, 2006 08:53 AM
94ls
Jun 7, 2005 01:52 PM
jsteezy1290
May 27, 2005 07:50 AM
