Thinner headgasket, and cam timing?
After the installation of a Mugen head gasket what degrees does it affect the cam timing by? ie. how many degrees does it advance the cams?
Austin
Austin
A thinner head gasket will retard the timing of the camshafts, not advance it. I have the Spoon two ply gasket and it retarded the camshafts by approx. 2 degrees.
The Mugen gasket should be similar.
[Modified by JPP, 1:14 PM 2/6/2002]
hmmmm.......2 degrees though? crank i presume correct?
[Modified by JPP, 2:42 PM 2/6/2002]
Thats two degrees on each camgears.
When the crankshaft is aligned with it's mark (TDC), the two marks that are suppose to be aligned to each other on the cam gears are separated by the widht of the tip of a teeth. You have to advance each camshaft the equvalent of half the width of the teeth so they are retimed at "zero". This equate to approx. 2 degrees.
It is not hard to calculate. If I remember correctly, the camgears are 4" diameter, the tip of each teeth is about 1/8" wide so
(1/8 x 360 degrees) / (4"x3.1416) = 3.58 degrees. Half of that is 1.8 degrees for each camshaft (approx. of course)
[Modified by JPP, 3:26 PM 2/6/2002]
2 degrees crank? Damn, isn't that quite a bit? So I'll advance the cams by 2 degrees crank when the head gasket goes in.
Thanks,
Austin
So changing the headgasket without viariable cam gears might hurt the performance of the engine as a result of poorer cam tunning!?
Hey Mike, if/when they put my motor back together, you going to peal a layer off the head gasket? I should have to worry about timing or anything with that litttle of a change right?
I've always been under the impression that every 10 thousandths removed was 1 degree retard on the cams.
I'd go with a 1 layer. Bottom black layer w/ copper spray.
