How does a headgasket affect timing?
Old Apr 17, 2002 | 07:15 PM
Rob :190:'s Avatar
Default How does a headgasket affect timing?
A friend of mine has a mugen headgasket on his ITR. How does this affect timing?
thanks
Old Apr 17, 2002 | 07:29 PM
khoalie's Avatar
Default Re: How does a headgasket affect timing? (Brian Spilner 1035)
it doesn't
seriously, why would it? the most it could do is bring the compression up a few points.
Old Apr 17, 2002 | 07:30 PM
Rob :190:'s Avatar
Default Re: How does a headgasket affect timing? (khoalie)
so it doesnt? so a thinner headgasket, which brings the head closer to the block, doesnt throw off the timing a bit?
Old Apr 17, 2002 | 07:45 PM
Casey's Avatar
ttt id like to know, thanks
Old Apr 17, 2002 | 07:56 PM
Big B's Avatar
Default Re: How does a headgasket affect timing? (TypeRformewhenIB18)
Yes it does effect cam timing. I'm not for sure how much though .There were some great threads about this on the endyn page but thats no longer there.
Old Apr 17, 2002 | 08:18 PM
filetofit
Guest
Posts: n/a
Default Re: How does a headgasket affect timing? (Big B)
I used to think it didn't affect timing but technically it does. If you take the amount that you are reducing the thickness of the head gasket by, say 0.040 inch, divide by the radius of the cam gear, about 2 inches, and multiply by 180/pi you'll get the angle in degrees that your cams get retarded. In this example about 1.146 degrees.
rol1in0n20s
Nov 25, 2007 08:27 AM
Cyphear
Nov 22, 2004 03:12 AM
Mr.Integra
Mar 15, 2003 10:20 PM
J T*
Jul 2, 2002 04:27 PM
Rob :190:
Apr 17, 2002 09:47 PM
