Timing
Old Dec 30, 2007 | 10:19 PM
D16SohcVtec's Avatar
Default Timing
So I've been doing a little bit of research etc on my project. I'm trying to lower compression a little bit using a thicker head gasket. I figured that after using a thicker head gasket cam timing will be advance about 2.5 degrees. Are cam gears nessesary? Or can I get away with not using them.
Modified by D16SohcVtec at 1:05 AM 12/31/2007
Old Dec 31, 2007 | 12:42 AM
mtber's Avatar
Default Re: Timing (D16SohcVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">So I've been doing a little bit of research etc on my project. I'm trying to lower compression a little bit using a thicker head gasket. I figured that after using a thicker head gasket cam timing will be advance about 2.5 degrees. Are cam gears nessesary? Or can I get away with not using them.
Modified by D16SohcVtec at 1:05 AM 12/31/2007</TD></TR></TABLE>
You should get a set of camgears
Old Dec 31, 2007 | 07:46 AM
dester223's Avatar
Default Re: Timing (mtber)
One for his and one for his buddy. DUH! SOHC POWA
Old Dec 31, 2007 | 11:00 AM
007EG's Avatar
Default Re: Timing (dester223)
yes, you definately will need an adjustable cam gear.
https://honda-tech.com/zerothread?id=2182486
rol1in0n20s
Nov 25, 2007 08:27 AM
N1 Andy
Nov 4, 2006 01:32 PM
jdm ek9 101
Sep 12, 2006 07:00 AM
spooledex
Dec 30, 2003 09:45 AM
TheSwift1
Nov 20, 2002 06:57 AM
