THUMPING SOUND from front passenger side axle????
Old May 20, 2005 | 04:16 PM
Hatch It's Avatar
Default THUMPING SOUND from front passenger side axle????
FIXED, thanks
Modified by Hatch It at 11:33 PM 7/6/2005
Old May 20, 2005 | 06:04 PM
silverEG6's Avatar
Default Re: THUMPING SOUND from front passenger side axle???? (Hatch It)
check your wheel bearings
Old May 20, 2005 | 07:24 PM
t0ekn3e's Avatar
check to see if its your knuckle i had that sound and it was the knuckle caste nut went bye bye and there went my fender and axle
Old May 20, 2005 | 07:26 PM
civicboisi's Avatar
Default Re: (t0ekn3e)
ball joints, lca bushings, and wheel bearings
Old May 20, 2005 | 07:39 PM
Aphelion's Avatar
Default Re: (civicboisi)
It is your axle. More specifically one of your CV joints, but that means you get to buy a new axle anyway $140 - $70 (core return) = $70 at your local auto parts store.
Old May 20, 2005 | 07:56 PM
CrX-To-Tha-Max-v2.0's Avatar
Default Re: (Aphelion)
Im having the same problem with front drivers side. It's like thud thud thud, as I start driving.
When I turn left it goes away a little bit, when I drive straight or to the right, it gets louder. Jerks the wheel at high speeds too..Wanna figure out what it is damn it.
Old May 20, 2005 | 08:14 PM
PhreeStyleHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion &raquo;</TD></TR><TR><TD CLASS="quote">It is your axle. More specifically one of your CV joints, </TD></TR></TABLE>
^ check your boots for cracks or leaks.
Old May 20, 2005 | 08:19 PM
paulbeezie's Avatar
Unload the passenger side while driving. Just vier the car to the left to take the weight off of the right side and if the noise goes away it's the wheel bearing.
Old May 20, 2005 | 09:43 PM
isumase's Avatar
Default Re:
check your cv joints. with the car being lowered it is constantly flexed instead of only flexing when going over bumping and its not operating at the angle it was intended to.
Old May 20, 2005 | 10:06 PM
GeeSssAre's Avatar
deff. check the cv boots. have you looked at the motor mounts?
timcali69
Aug 7, 2007 08:52 AM
Elmo1968
Oct 18, 2006 10:18 AM
Honduh@Love
Aug 30, 2005 02:18 PM
futurefastguy
Mar 28, 2005 06:47 PM
KuyaCyd
Apr 19, 2004 08:27 PM
