engine problems after swap
Old May 20, 2005 | 09:45 AM
pappabear's Avatar
Default engine problems after swap
i have a 92 civic hb and i swapped in a b16a2 and the engine wont turno over and doesnt sound like it wants to but i have power in the car and the fuel pump does turn on and i check the grounds and there is power going to them what can it be??
Old May 20, 2005 | 09:46 AM
JDubbs99Civic's Avatar
Default Re: engine problems after swap (pappabear)
do a compression test and come back with more info
Old May 20, 2005 | 10:08 AM
IHateJDM's Avatar
Default Re: engine problems after swap (JDubbs99Civic)
you need 4 things to start an engine.
1. Fuel
2. Spark
3. Timing
4. Compression
Make sure you have all of these.
Old May 20, 2005 | 10:15 AM
SirRevvs's Avatar
Default Re: engine problems after swap (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">you need 4 things to start an engine.
1. Fuel
2. Spark
3. Timing
4. Compression
Make sure you have all of these.</TD></TR></TABLE>
Double check timing. You're saying it cranks but won't start correct?
Old May 20, 2005 | 10:17 AM
pappabear's Avatar
no sorry it wont even turn over no crank but i have power in the car
Old May 20, 2005 | 10:20 AM
IHateJDM's Avatar
start with starter or battery. Just because the car has power does not mean the battery has enough power to turn the starter.
Old May 22, 2005 | 04:55 PM
pappabear's Avatar
i dont know what to do anymore with the car
Old May 23, 2005 | 10:12 AM
AlpineInstaller's Avatar
Default Re: (pappabear)
Probably the starter... Is it even getting 12V? Stick a voltmeter on the starter wire at the starter. Check if it gets 12V with key in start position. Check all of your fuses again. You'd be surprised...
Old May 23, 2005 | 11:14 AM
-Darren-'s Avatar
check your starter.
Old May 23, 2005 | 11:20 AM
SuperSteve737's Avatar
Give it to me.
Hit the starter a few times with a hammer and try starting it again.
Old May 23, 2005 | 11:22 AM
IHateJDM's Avatar
Default Re: (-Darren-)
have you tried jumping it off another car? if that doesn't work, put a multimeter on the starter. maybe the car doesn't see the clutch pedal as being down when you start it.
Old May 23, 2005 | 11:57 AM
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">have you tried jumping it off another car? if that doesn't work, put a multimeter on the starter. maybe the car doesn't see the clutch pedal as being down when you start it.</TD></TR></TABLE>
to the clutch pedal sensor
NwAmH
Nov 7, 2014 08:30 PM
91DA buffalo
Aug 2, 2011 12:06 PM
jonnybadboi9
Jul 15, 2009 09:39 PM
doood
14
Mar 31, 2007 04:58 PM
wpgcivic
23
Dec 30, 2004 08:49 AM
