Another no starting car!!!
i just changed the battery and it turns over but doesnt start and it doesnt sound like it wants to fire, the sound of the engine doesnt change compared to a regular engine when you crank it the sound pitch goes up and down, any ideas?
Re: (wpgcivic)
make sure your battery terminals are screwed down tightly.
take apart your starter and have it tested at a local autozone.
take apart your distributor and check your ignition coil. see if it has burnt marks or if it smells funny.
ABK read up, i have spark adn fuel, distribuster is BRAND NEW, i guess maybe its the starter, but wouldnt it not turn over at all?
Re: (mr_ducksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce »</TD></TR><TR><TD CLASS="quote">did anything weird happen with the car? over heat or something?</TD></TR></TABLE>
nothing wierd happened, started it yesterday, let it run for about a half hour, no over heating
Re: (wpgcivic)
Kinda sounds like your starter isn't engaging the flywheel from your description. Pull a spark plug and put your hand over the hole and feel for compression.
when i put my hand over the whole should i feel air come out? if so is that what i want? and if nothing happens?
also could my starter be shot?
be professional
Re: ($300lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $300lude »</TD></TR><TR><TD CLASS="quote">Kinda sounds like your starter isn't engaging the flywheel from your description. Pull a spark plug and put your hand over the hole and feel for compression.</TD></TR></TABLE>
If he is getting spark, then the distributor is turning, so the engine has to be cranking.
Re: (wpgcivic)
If the starter wasnt enguaging the flywheel, you would know it. It sounds nothing like the engine turning over. It is an awful high pitch screetching sound.
If you are 100% sure you are getting fuel and spark, I would check your cam timing and then do a compression check.
Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">i dont know, i got the engien adn swapped it in so i guess the person before already had it bent</TD></TR></TABLE>
bent valve is not that bad just as long as it didn't mess up anything else
is it a d series?
is it a d series?
junya16
03-01-2003 05:41 PM
