Cleaning bare block.
Old May 19, 2005 | 05:22 PM
ildknyli's Avatar
Default Cleaning bare block.
The block is very dirty(lots of dirt and oil). Just wondering how should I clean it myself. Should i just use engine degresser and a pressure washer? Also could I just dry it with towels or should I use an air compressor to dry it? Do I need to remove the oil squirters?
Old May 19, 2005 | 06:40 PM
93turbo16's Avatar
is everything removed? I did it with a pressure washer and soapy water.. then make sure you get the bore coated with oil or something to prevent the rust. But on the exterior I used a little steel wheel and some degreaser.
Old May 20, 2005 | 08:23 AM
legendboy's Avatar
Default Re: (93turbo16)
take it to a machine shop and get it bead blasted
No way you can get it too look that good and its usually cheap. Here's a pic of my engine and tranny case i just had done.
Old May 20, 2005 | 08:38 AM
PrettyLude's Avatar
hottank it
Old May 20, 2005 | 02:34 PM
ildknyli's Avatar
Everything is out, its bare.
93turbo16 did you get it as clean as legendboy's block?
How much does bead blasting usually cost?
What should I coat with oil to prevent rust?
Old May 20, 2005 | 03:29 PM
notstock93's Avatar
Default Re: (ildknyli)
When I wanted to make mine new looking I just cleaned it with a bristle brush and simple green mixed with random degreasers. I got it clean,rinsed it, then painted it with a light coat of aluminum block paint. Looked like a jewel sitting in the garage. This was before honing, as the water may rust the cylinders if left alone too long. You can just spray the walls with lube if it worries you.
Old May 22, 2005 | 06:23 AM
ildknyli's Avatar
Default Re: (notstock93)
Are the cylinder walls the only thing that I should be worried about rusting?
Also what lube should I use? Just some regular motor oil?
Old May 22, 2005 | 12:15 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Are the cylinder walls the only thing that I should be worried about rusting?
Also what lube should I use? Just some regular motor oil?</TD></TR></TABLE>
Pretty much, everything else is Alum.
Use some WD-40, works fine. It wont really be a big issue unless you are keeping the block for months.
Old May 22, 2005 | 12:25 PM
ildknyli's Avatar
Its going to sit there for a few months. Just saving up to get it sleeved and built by earl.
Old May 22, 2005 | 09:56 PM
notstock93's Avatar
If its getting sleeved to a different bore, then obviously you dont need to worry abotu any sort of rusting. The new sleeves will be perfect.
Old May 23, 2005 | 04:53 AM
EG6R's Avatar
Default Re: Cleaning bare block. (ildknyli)
I used a metal polish, autosol. It worked fine just to get the stains off and restore the orig finish
Mobeious
Dec 29, 2012 02:30 AM
sgnlab
Sep 28, 2011 02:12 PM
EFPhilly
19
Dec 24, 2009 04:51 PM
gutted
Aug 20, 2005 09:55 PM
MeanGreenEG9
Jan 13, 2003 01:40 PM
