Connecting Rod Problem!!!!
Old May 18, 2005 | 05:37 PM
Radyjr's Avatar
Default Connecting Rod Problem!!!!
i got a quick question about b16a2 rods. i bought a set of rods off a guy here (honda-tech) and he gave me all 4 connecting rods that say 2 on them. can i still use them, and also how can i identify which piston is which just incase ...
Old May 18, 2005 | 06:19 PM
Radyjr's Avatar
Default Re: Connecting Rod Problem!!!! (Radyjr)
bump
Old May 18, 2005 | 06:21 PM
Archidictus's Avatar
Unceasing Measure
Are they stock or aftermarket?
Old May 18, 2005 | 06:33 PM
Radyjr's Avatar
Default Re: Connecting Rod Problem!!!! (Archidictus)
stock
Old May 19, 2005 | 07:43 PM
b18dude's Avatar
is the number half on the rod and the other half on the rod bearing cap? if so that just tells u what bearings to use
Old May 20, 2005 | 03:20 PM
Radyjr's Avatar
Default Re: (b18dude)
the bearing cap and the rods say 2 all 4 of them
Old May 21, 2005 | 04:29 AM
b18dude's Avatar
now u match those numbers to the appropriate letters on the crank and BAM there are your rod bearings. good luck man
Old May 22, 2005 | 06:58 AM
Radyjr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18dude &raquo;</TD></TR><TR><TD CLASS="quote">now u match those numbers to the appropriate letters on the crank and BAM there are your rod bearings. good luck man </TD></TR></TABLE>
All the cap and rods say 2 though, i thought they are saposed to be labled 1,2,3,4
not 2,2,2,2
Old May 22, 2005 | 07:20 AM
b19coupe's Avatar
Default Re: (Radyjr)
It does not matter what cylinder you put them in. They are not #1-#2-#3-#4. The 2 tells you what size they are so you have an idea what bearings to use. Get a Helms.
Old May 22, 2005 | 07:41 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr &raquo;</TD></TR><TR><TD CLASS="quote">
not 2,2,2,2</TD></TR></TABLE>
you have a lot to learn
Old May 22, 2005 | 09:31 AM
Radyjr's Avatar
Default Re: (senpai)
ok, now what does the number 2 mean in bearing size then..... i am a newbe
Old May 23, 2005 | 09:11 PM
b18dude's Avatar
there are letters on the crank where the rods go and u match those letters with the numbers on the rods
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
kornerk12
12
Jul 21, 2007 08:37 PM
EARLdaSQUIRREL
May 31, 2007 12:19 PM
unknown0001
Jul 3, 2005 07:48 AM
SOHCD16y8
May 21, 2005 12:32 AM
