Head Gasket Leak
Old May 18, 2005 | 02:04 PM
jbs's Avatar
jbs
Default Head Gasket Leak
I had a rod know and have purchased a used block here on HT. Anyhow, I transferred my old head to the new block using a new OEM head gasket. After moving the engine around when installing the flywheel, I've notice an oil leak by the head gasket. I rechecked the torque on the head bolts and all are into spec. I've been told that the OEM head gaskets are a one time use deal. I was wondering what you'all think if I took it out and spray on a permatex copper adhesive sealer. As a note, my old engine did not leak what so ever. I figured the block I bought doesn't have a perfectly flat deck. This is my guess why there is a leak. Anyone who has experienced this please post up some comments/advise. Thanks!!!
Old May 18, 2005 | 02:07 PM
EG6 SiR's Avatar
Default Re: Head Gasket Leak (jbs)
Id say yes you can reuse it, but it also depends on how long you were running it for.
Old May 18, 2005 | 02:15 PM
Turbo E's Avatar
which is easier
1. take the head apart, spraying and reinstalling the head and removing it a 2nd time cuz it still leaks, then buying a new OEM HG
2. replacing the HG with a new OEM once. AKA the right way.
Old May 18, 2005 | 02:18 PM
EG6 SiR's Avatar
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">which is easier
Very true, but for a guy on a budget, it may be worth a shot. Plus pulling a head isnt all that bad.
Old May 18, 2005 | 02:29 PM
Turbo E's Avatar
Default Re: (EG6 SiR)
i know where ur coming from. well if you got the time, go for it. personally, i hated doing my HG. almost as bad as the clutch.
if your head/deck is warped....
Old May 18, 2005 | 02:54 PM
saleensolution's Avatar
i agree pulling the head gets old. just buy a new one and you wont have to worry about it. and i know you said you were on a budget but save yourself some labor and head ache get a gasket
Old May 18, 2005 | 03:39 PM
jbs's Avatar
jbs
Thanks for the replies. I guess I wasn't making myself clear. The head gasket is brand new. I just replaced it. I havn't ran the engine. I have however torque it down already. That's when I noticed the leak. I'm hoping the copper sealant/adhesive works and someone here has done it. Anyone?
Old May 18, 2005 | 03:42 PM
jbs's Avatar
jbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">if your head/deck is warped.... </TD></TR></TABLE> Turbo E do you think a warped deck (block) will be saved by a copper sealant enought to where it won't leak? I guess its how far the deck (block) is it from being flat.
Old May 19, 2005 | 03:00 PM
jbs's Avatar
jbs
Old May 19, 2005 | 03:05 PM
EJ1 wilcox's Avatar
Default Re: (jbs)
Once you torque the studs down the headgasket crushes... that's why it's only good for one use...
If you take the head off you have to replace the headgasket, it will be crushed from when you tightened the studs and will not seal correctly the second time.
I wouldn't take chances with copper spray, just go buy a new headgasket.
Old May 19, 2005 | 03:49 PM
civicboisi's Avatar
Default Re: (EJ1 wilcox)
^ to add to that...did you get new head bolts? Or did you reuse the old head bolts? That could be the culprit too...the bolts, from what i understand, are good for being torqued once...you might be able to get away with it twice Dunno...just an idea...someone could elaborate more on this...
Old May 25, 2005 | 11:17 AM
Turbo E's Avatar
Default Re: (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote"> Turbo E do you think a warped deck (block) will be saved by a copper sealant enought to where it won't leak? I guess its how far the deck (block) is it from being flat.</TD></TR></TABLE>
you will have to get the head "decked" flast. no amount of copper spray , tire gel, shoe goo or JB weld will help.
keep your fingers crossed.
turbodailydan
Jul 19, 2009 07:54 PM
teddy_dc2
Jul 26, 2008 09:46 PM
tom4691
May 17, 2007 08:46 AM
konio
Jul 15, 2006 09:54 PM
