Help on timing jumper
Re: Help on timing jumper (spockeg)
heres a pic of what jumper to use.... its not the 3 wire its the 2 wire jumper. also if you car is newer than 93 than you dont have to use the jumper it will set your timing way off.
Re: Help on timing jumper (siregcivic)
Man that's a huge blurry *** picture
Yeah, just use the 2 wire clip... jump it with a paperclip or whatever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">...if you car is newer than 93 than you dont have to use the jumper it will set your timing way off.
Wha?
Any support to this? I have always jumped my connector when setting my timing ('95) and it's fine. This is the way the manual says to time it.
Wha?
yah thats what the chilton manual said 93 and below you jump the connector and it says 94 up you dont. i dont know. i went to get my **** bar'd and the guy jumped the ecu and he said my timing was 23 degrees off????
but anyway heres another pictar for you... also ive always timed my **** without the jumper.
Got it timed. tryed with out a jumper and it had to much timing at a idle. Then i backed it off and it with the jumper and it idles and runs like a champ
THANKS FOR HELPING
THANKS FOR HELPING
themorphious
06-06-2006 02:44 PM
