head gasket question
Old Jul 26, 2008 | 07:50 PM
teddy_dc2's Avatar
Default head gasket question
i did an arp head stud upgrade for the turbo teg a while back, people were telling me go with oem head gasket cause i was only doing 7 psi. the thing i realize was the torque specs for the arp are much more than stock studs and this is an oem gasket, since then there has always been a slight oil leak between the head and block, it's also leaking from else where like the cam seal. i've been itching to replace it with a cometic this time but have any of you guys have the same problem with arp on oem hg? (also fixing other leaks) also where can i get a good deal on a 81mm cometic head gasket or a kit?
Old Jul 26, 2008 | 08:18 PM
teddy_dc2's Avatar
is there a break in period necessary? cause i just kinda took it for a beating....
Old Jul 26, 2008 | 09:34 PM
blinx9900's Avatar
Default Re: head gasket question (teddy_dc2)
i had my head and block both resurfaced, cometic hg with copper spray and ARP headstuds and i have never had a leak, and no there is no break in period.
question though, do you have any sort of crankcase ventilation? Sometime crankcase pressure shoots up and causes loads of leaks...
Old Jul 26, 2008 | 09:46 PM
teddy_dc2's Avatar
that's what im going to add with the cometic h.g. when i do, a breather kid in the back of the block.
hamizle
Dec 1, 2009 04:55 PM
b17 rolla
Jan 19, 2009 09:12 PM
SOHCex20
Aug 29, 2005 01:28 PM
rschoener
Aug 18, 2003 07:48 AM
