Piston to Deck Height for D16Z6 with PM6 Pistons...
Old May 17, 2005 | 09:22 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Piston to Deck Height for D16Z6 with PM6 Pistons...
Anyone know what it is?
http://www.knology.net/%7Ejediklc/D.htm
I don't know what to punch in.
Old May 17, 2005 | 09:27 PM
civictildeath's Avatar
Default Re: Piston to Deck Height for D16Z6 with PM6 Pistons... (GapxGuy)
i would say 0.02 or leave it be at 0
Old May 17, 2005 | 10:35 PM
GapxGuy's Avatar
Default Re: Piston to Deck Height for D16Z6 with PM6 Pistons... (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">i would say 0.02 or leave it be at 0</TD></TR></TABLE>
That's a .5 CR difference, I need to know which one.
Old May 18, 2005 | 08:31 AM
GapxGuy's Avatar
Bump
Old May 18, 2005 | 08:48 AM
Deemeetree's Avatar
Electrician
0.5 total difference.
1mm = .040
0.5 = .020
.020 is your final answer.
Piston Deck Clearance Formula
Deck Height - Compression Height - Rod Length - (Stroke/2) = Piston Deck Clearance
This is using a stock D16Z6 block, D16Z6 head, D16Z6 rods, D16Z6 head gasket with PM6 pistons.
Should yield 9.95 compression. Not bad. A little low for good power.
Use a D16Y8 2-layer headgasket, 10.23 compression.
Old May 18, 2005 | 08:51 AM
GapxGuy's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">0.5 total difference.
1mm = .040
0.5 = .020
Use a D16Y8 2-layer headgasket, 10.23 compression. </TD></TR></TABLE>
Thank you.
Old May 18, 2005 | 09:14 AM
docmanakos's Avatar
Why not use a PM7 piston? Make some power and regain some torque.
Docmanakos@aol.com
Yiasou Demetri
Old May 18, 2005 | 10:08 AM
GapxGuy's Avatar
Default Re: (docmanakos)
Those are ZC pistons right? What's Piston to deck height for those? 0.04? Is the D16A1 block the same specs. as other D16 blocks?
I didn't know what PTDH to put for the ZC pistons, so the CR came out to be 13+.
Old May 18, 2005 | 10:19 AM
Deemeetree's Avatar
Electrician
Default Re: (GapxGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">Those are ZC pistons right? What's Piston to deck height for those? 0.04? Is the D16A1 block the same specs. as other D16 blocks?
I didn't know what PTDH to put for the ZC pistons, so the CR came out to be 13+.</TD></TR></TABLE>
.040 using P29 pistons
D16Z6 block
D16Z6 head
D16Z6 headgasket
12.03 compression
Now we're talking.
If it's possible, which I think it is. Get with http://www.d-series.org and ask away. More info over there.
Old May 18, 2005 | 08:40 PM
GapxGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">.040 using P29 pistons
D16Z6 block
D16Z6 head
D16Z6 headgasket
12.03 compression
Now we're talking.
If it's possible, which I think it is. Get with http://www.d-series.org and ask away. More info over there.</TD></TR></TABLE>
That's more like it! I always thought A1 pistons would bump the CR in the 13's. Now I can accomplish 12:1 CR without milling the head.
93EH6
28
Mar 29, 2004 08:24 PM
c0nspire
Mar 1, 2004 03:46 PM
booscivic
Sep 28, 2003 05:34 AM
