air fuel ratio????
Old May 15, 2005 | 10:36 PM
siregcivic's Avatar
Default air fuel ratio????
aright i have a 92 civic cx hatch with a 93 d16z6 aem cold air port and polished exhaust no cat 2 1/4 piping. and for fuel i have a b16 del sol fpr and a b16 del sol fuel pump
my question is... during the day my car runs stoich at partial throttle and when its full thorttle its rich wich is normal right?
well when its night time and cooler it runs lean as **** when its partial throttle and when its full throttle it barely runs stoich
if anyone knows what the problem could be let me know.
Old May 15, 2005 | 10:56 PM
evosol's Avatar
Default Re: air fuel ratio???? (siregcivic)
i'm assuming your looking at a narrowband A/F gauge? If you are, it won't tell you anything usefull. best way to check if your not in a position to buy a wideband is check the plugs.
Old May 15, 2005 | 11:14 PM
JDMlyfestyle's Avatar
Ok back to tech..lol
Your stock Narrowband o2 isnt gonna tell you ****. its gonna give you a nice lil light show.
In order to get a accurate A/F ratio reading you need to get a Wideband o2 sensor. i would really recomend the PLX M300 wideband. it has outputs that can go to ur ECU if you are datalogging, and has a wire that can go to your A/F ratio gauge. but it comes with a digital display so the gauge isnt really needed
boosteddohczc
Jul 23, 2012 08:02 PM
EG6 Poe
18
Dec 6, 2007 08:00 AM
sick93sol
Aug 3, 2007 01:24 PM
hotinteggy
Oct 27, 2004 07:21 AM
5gen-hybrid
Aug 5, 2001 10:49 PM
