replacing a B-18c1 headgasket.. help
Old May 14, 2005 | 05:59 PM
Shizznaz's Avatar
Default replacing a B-18c1 headgasket.. help
The past few days I have been having trouble with my radiator, I thought that it was bad because the fluid would randomly just drain out completely and nearly cause my engine to overheat. but now I can see a greenish liquid coming from the head gasket on the front/left corner.. Its not like pouring out. but its kind of a gradual leak and something that I cant see happen. I guess it only leaks when im driving because it doesnt do anything when its at an idle when I can look for myself. So Im pretty sure that the gasket is blown. If not , let me know before I trouble myself too much..
But anyways, I was just curious if I could get a slight estimate on how many days it would take to replace it. Because its my daily driven car and id need to know if its a weekend thing or a full week thing so I can start planning ahead. Also, is there any performance head gaskets out there that I could get? So it can withstand more? ... Im not familiar at all with that area so Any help or suggestions would be great.
Thanks
EDIT: btw, thats my engine in the icon. and the leak is comming from the bottom left corner ( looking down on the engine ) if that helps at all.
Old May 14, 2005 | 06:01 PM
DeadVet's Avatar
Default Re: replacing a B-18c1 headgasket.. help (Shizznaz)
oem headgasket is fine. Are you doing this headgasket yourself? If so and its your first time i would give yourself a weekend.
Old May 14, 2005 | 06:25 PM
Shizznaz's Avatar
Default Re: replacing a B-18c1 headgasket.. help (1TurboHatch)
Thats the thing. I need to know if I will be able to do it by myself. My dad will be helping me. And he has worked on cars for a while now, but he has never done a honda engine before. Although that should make no difference as far as experience goes. But if It will be a struggle for me and my dad to do in a weekend, then I need to know so that way I can find time to look for a rental car while its being worked on.
And about the OEM headgasket, if there is a better one out there, Id rather get that one so that way I have it and I wont have to worry about getting one later on down the road.
Old May 14, 2005 | 06:28 PM
DeadVet's Avatar
If your leaving the car stock then oem is fine if your going to boost you can get a commetics headgasket but you dont need it. Should be able to do it without a problem in 2 days.
Old May 14, 2005 | 06:47 PM
Shizznaz's Avatar
I dont plan on boostin my car soon due to money issues, but I do want to as soon as possible. So Yeah Id like to get the best head gasket I can.
Old May 14, 2005 | 10:28 PM
PrettyLude's Avatar
best headgasket=oem
Old May 15, 2005 | 01:40 PM
Jmunk's Avatar
I would go with a OEM gasket.
Old May 15, 2005 | 02:53 PM
Dogginator's Avatar
Daisy... Daisy...
I recommend the following:
1) Helm's manual
2) Torque wrench (two are preferable, a 1/2" and 3/8" drive)
3) Air power and a good impact wrench for the crank pulley bolt
4) A good straight edge and feeler gages to check the head warpage. Otherwise, have a shop inspect your head. Also, check the block.
5) Replace your timing belt and water pump with OEM parts
6) OEM head gasket
You may want to do a compression check before starting to determine if any of the cylinders are compromised.
Old May 16, 2005 | 12:22 PM
Shizznaz's Avatar
Default Re: replacing a B-18c1 headgasket.. help (Dogginator)
Actually it wasnt my head gasket.
I stole my dads compression gauge thing, and I did a check on all 4 cylinders, and they all came up just fine .. Left to right, the numbers came up something like 135 135 145 140 ...
But I ended up fixing it and the problem was my thermostat. I took it out and put everything back together ( leaving the thermo. out .. ) and I started my car and checked everything and it didnt overheat or anything. So I check the thermo. out and all the rubber pieces were all corroded and **** so I bought a new one and replaced it all and Now my car is running great.
But what I think caused it, is that my radiator fan wasnt coming on. Apperently , the wires came out of the plug. But luckly I was able to stuff them back in and it works now. So yay, no weekend of replacing a gasket!!!. haha
AddiXz
Nov 3, 2013 06:02 AM
moosta936
Mar 4, 2007 04:14 PM
M2nR
16
Sep 1, 2006 08:04 PM
machine4321
Jul 2, 2004 11:56 AM
Import RP
Nov 5, 2001 07:44 PM
