C-Speed Compression Calculator...
Old May 13, 2005 | 10:17 PM
Terrible One's Avatar
Default C-Speed Compression Calculator...
i heard that most of the calculations on c-speed is accurate except the pct pistons. i want around 11:1 on the b16a (sir-2). i get 11.006336273672834 from the 1 layer head gasket. does anyone know if this is referring to the oem head gasket? if so, is this reliable? is anyone using a 1 layer oem head gasket on their b16 with no problems?
Old May 13, 2005 | 10:26 PM
nissanjon's Avatar
Default Re: C-Speed Compression Calculator... (Terrible One)
https://honda-tech.com/zerothread?id=717928
all the info you need on the topic.
it takes time but its worth it.
Old May 13, 2005 | 10:29 PM
Default Re: C-Speed Compression Calculator... (nissanjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissanjon &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=717928
it takes time but its worth it.</TD></TR></TABLE>
i've gone through that thread many times but it doesn't corcern my question. i'm trying to find the easiest, most reliable way to achieve around 11:1 compression on a b16a (sir-2). my other choice would be milling the head but i wanted to know if the 1 layer head gasket will do the job. thanks
Old May 14, 2005 | 09:10 AM
bump
Old May 14, 2005 | 12:16 PM
HondaIntegraR's Avatar
i think the c speed compression calculator becomes right when you put the right ptd height, i think its 0
Blue94Accord
Oct 23, 2010 04:00 PM
EF88Vtec
Oct 12, 2008 09:06 PM
PhatBoy5015
Mar 12, 2006 11:27 AM
xyzalvarez
31
Sep 5, 2005 09:54 AM
prdtr15
Sep 25, 2003 03:45 PM
