6" or 8" JRC?
Old May 13, 2005 | 09:31 PM
blackoutcivic's Avatar
Default 6" or 8" JRC?
I had done a search on the topic and stumbled on some links to articles that basically summed up that bigger is not always better as far as intercoolers go.
For a 6-8 psi setup which of the JRC intercoolers would be most approriate? Looking for a good balance of pressure/cooling for a daily driver.
Old May 13, 2005 | 11:12 PM
95GSRTT
Guest
Posts: n/a
Default Re: 6" or 8" JRC? (blackoutcivic)
Old May 13, 2005 | 11:16 PM
urbansi's Avatar
t-3/t-4 sounds good, with a bar and plate intercooler
Old May 14, 2005 | 07:36 AM
Turbowa's Avatar
It depends on alot more then just how many psi you want to run. Need to know a little more info. Like what turbo, power goal, ect. ect.....
Old May 14, 2005 | 08:29 AM
Default Re: 6" or 8" JRC? (Turbowa)
thinking about running either a t3/t4 57trim or a GT3251E
Goal is ~ 250-270hp at 7psi (daily driven)
Old May 14, 2005 | 10:20 AM
95GSRTT
Guest
Posts: n/a
like i said 6". At his original goal of 6-8 psi, it really doesnt matter what his power goals are. If you are only running 6-8 lbs the chance that hes retarded and gonna run a t88 turbo are VERY unlikely 250-300 hp you will be fine with te 6"
Old May 14, 2005 | 01:27 PM
adseguy's Avatar
Default Re: 6" or 8" JRC? (95GSRTT)
6"...can't go wrong with the 8" though it'll work just as good.
Old May 14, 2005 | 02:02 PM
beerbongskickass's Avatar
Default Re: 6" or 8" JRC? (adseguy)
My 5 inch has been working fine for me. I would go with the 8 inch if I was you incase you want to build your motor in the future.
Cole89ef
Aug 6, 2009 07:03 AM
OrangeBoost
Apr 17, 2006 05:03 AM
Elemental
Jan 13, 2005 06:23 AM
Del_Slowest
Oct 27, 2004 12:08 PM
ludelvr
Nov 3, 2002 11:33 AM
