6" or 8" JRC?
6" or 8" JRC?
I had done a search on the topic and stumbled on some links to articles that basically summed up that bigger is not always better as far as intercoolers go.
For a 6-8 psi setup which of the JRC intercoolers would be most approriate? Looking for a good balance of pressure/cooling for a daily driver.
Re: 6" or 8" JRC? (blackoutcivic)
It depends on alot more then just how many psi you want to run. Need to know a little more info. Like what turbo, power goal, ect. ect.....
Guest
Posts: n/a
like i said 6". At his original goal of 6-8 psi, it really doesnt matter what his power goals are. If you are only running 6-8 lbs the chance that hes retarded and gonna run a t88 turbo are VERY unlikely 250-300 hp you will be fine with te 6"
OrangeBoost
04-17-2006 05:03 AM
Elemental
01-13-2005 06:23 AM
