how to align the timing marks?
Old May 12, 2005 | 09:14 PM
civic_tuned's Avatar
Default how to align the timing marks?
My timing is off and i want to align everything correctly. How to u align the timing marks i know the cam sprocket has to be be at 12 o'clock w/ the up engraving but what about the crankshaft pulley do i go about the two white marks and the red in the middle or the white mark that is about 1in apart. This is on D16Z6. thanks in advance!
Old May 12, 2005 | 09:18 PM
jdm.ej's Avatar
Default Re: how to align the timing marks? (civic_type_r)
you use the white mark not the other three marks.
Old May 12, 2005 | 09:28 PM
Default Re: how to align the timing marks? (jdm.ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ej &raquo;</TD></TR><TR><TD CLASS="quote">you use the white mark not the other three marks. </TD></TR></TABLE>
just out of curisousity.....what is the red w/ the whites for? The reason i ask cause on the haynes book has the red mark aligned with the pointer.
Old May 12, 2005 | 09:35 PM
jdm.ej's Avatar
it might be for the oil pump line.
Old May 12, 2005 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ej &raquo;</TD></TR><TR><TD CLASS="quote">it might be for the oil pump line.</TD></TR></TABLE>
dammm!! my tdc on the crank is way off! The car would run sort of strong but wanted to stall,pop, stutter. So i used the timing gun but went with the red mark. i adjust the dizzy but its still off and now the laggs but with the same problems before. Do u think if i replace the timing belt(tensior still good) will the valves be okay!
Old May 12, 2005 | 09:52 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">
just out of curisousity.....what is the red w/ the whites for? The reason i ask cause on the haynes book has the red mark aligned with the pointer. </TD></TR></TABLE>
Wrong, those 3 are for timing with a timing light.
- TDC
- 16 BDC
- 14 BDC
- 12 BDC
I think thats the degrees.
Old May 12, 2005 | 09:56 PM
Default Re: how to align the timing marks? (Luserkid)
so which one is if im not going to use the timing is the white mark?
Old May 12, 2005 | 09:58 PM
Luserkid's Avatar
If your putting a timing belt on and need to set everything to TDC then you use the mark thats by itself (if you dont see white its just the notch thats there).
When your done and the car is running take a timing light to it and see what reading its giving and you use the other 3 to read.
Old May 12, 2005 | 10:04 PM
thanks mang! What im worried about is the valves.
-Do u guys think ill be okay!
EX-T
13
Oct 29, 2008 06:07 AM
Blackice087
Mar 21, 2008 06:40 PM
handa
13
Jul 31, 2004 05:19 PM
88rexdxa6ed
Apr 24, 2004 11:51 AM
allmotor.net
Nov 8, 2002 08:45 AM
