turbo on an auto D16Y8
Old May 12, 2005 | 11:13 AM
chile's Avatar
Default turbo on an auto D16Y8
i read a few posts on this and was wondering if the torque converter is really all i need to take care of...one post read 150HP is doable on the stock converter but i wanna be sure...i don't plan to run the crap outta the car...maybe once in a while...any help/suggestions (besides a b series swap) is appreciated. thanks all.
huntarrr's Avatar
Default Re: turbo on an auto D16Y8 (chile)
manual swap first, then turbo. you'll thank me.
Old May 12, 2005 | 11:15 AM
chile's Avatar
Default Re: turbo on an auto D16Y8 (vsm98civic)
i've done a manual swap before on a 76 fairlady (but that was a loooooonngg time ago)...how much will a 5 spd run me?
Old May 12, 2005 | 11:17 AM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">manual swap first, then turbo. you'll thank me.</TD></TR></TABLE>
The torque converter is the least of your issues...... Just do an auto to manual swap then boost it to hell.
The price of the swap will vary depending on the prices you get for parts and if you do the work yourself.
Old May 12, 2005 | 11:28 AM
civiccpedx's Avatar
Default Re: turbo on an auto D16Y8 (SOHC4life 96)
i have seen shops charging anywhere from 1000-1500, check around at local shops, but i would recommend finding your own parts, it'll be cheaper.
personaly i would just sell the car, and buy a manual
Old May 12, 2005 | 11:31 AM
SkElLyTuRbO's Avatar
Default Re: turbo on an auto D16Y8 (civiccpedx)
Go to a junkyard and find the pedal assembly and shift linkage and rewire your own ignition and you'll save some money on the swap. Do as much as possible on your own before throwing it into the hands of a money hungry shop. Just my .02.
Old May 12, 2005 | 11:34 AM
chile's Avatar
Default Re: turbo on an auto D16Y8 (SkElLyTuRbO)
yeah, i know a guy that can help me out....thanks all...so is this undoable with an auto or just nonfeasible?
Old May 12, 2005 | 11:35 AM
civiccpedx's Avatar
the auto tranny couldn't handle that much power, and it wouldn't be that fun to drive.....just not worth it.....at all
but it could be done i guess
Old May 12, 2005 | 11:38 AM
sohcvtec66
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chile &raquo;</TD></TR><TR><TD CLASS="quote">i read a few posts on this and was wondering if the torque converter is really all i need to take care of...one post read 150HP is doable on the stock converter but i wanna be sure...i don't plan to run the crap outta the car...maybe once in a while...any help/suggestions (besides a b series swap) is appreciated. thanks all.</TD></TR></TABLE>
buy at D15B VTEC From http://www.hmotorsonline.com with the tranny, then buy a OEM vx timing belt,water pump, and all new gaskets, and you will be fine, then turbo it
Old May 12, 2005 | 11:51 AM
flood's Avatar
Only if its a 4 door
Old May 12, 2005 | 11:59 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkElLyTuRbO &raquo;</TD></TR><TR><TD CLASS="quote">Go to a junkyard and find the pedal assembly and shift linkage and rewire your own ignition and you'll save some money on the swap. Do as much as possible on your own before throwing it into the hands of a money hungry shop. Just my .02. </TD></TR></TABLE>
have you ever done this?
you don't touch the ignition.
Old May 12, 2005 | 07:39 PM
5thGenCivicKid's Avatar
you need hydro lines,pedals,tranny,clutch flywheel deff get the mount if its in a eg and has nothing to do with ign at all
Old May 12, 2005 | 07:54 PM
isumase's Avatar
Default Re: (5thGenCivicKid)
i did this on my 93 coupe, not turbo but 5 spd swap, and LOVE it!!! car is SOOOO much more playful than it ever was before. all you really need is the parts to do the swap, i paid someone to do it cause i dont really have time or the garage space to do it and it cost about a grand but if you know someone that knows what theyre doing yuo should be fine. one recommendation, replace clutch assembly and flywheel(optional but not necessary) and definitely CHECK IMPUT SHAFT BEARING!!! i made this mistake and it cost me quite a bit. good luck and let us know progress
Nikademo
Acura TL, RL & ZDX
Jan 14, 2017 11:03 PM
jay0504
Apr 20, 2014 06:01 PM
Brandeezy1
Jun 28, 2010 08:51 PM
EJ6_MR
Jan 14, 2007 07:17 PM
