b20 vtectekers....what cam gears are you running and what setting..
Old May 12, 2005 | 09:44 AM
ek2k's Avatar
Default b20 vtectekers....what cam gears are you running and what setting..
what are most of you crvtec running as far as cam gears(sprockets) and what setting do you find to be the best for your setup..
i'll go first
Skunk cam gears and setting at 2+ & 1-
Old May 12, 2005 | 09:52 AM
ek2k's Avatar
bump for looking,,
Old May 12, 2005 | 09:55 AM
SkRiBLaH's Avatar
Default Re: (ek2k)
it all depends, thats one tool thats used to tune the car.
Old May 12, 2005 | 10:01 AM
ek2k's Avatar
Default Re: (SkRiBLaH)
yeah i know thats why i have that setting and i was wondering if thats the setting you guys have after tunning your car?? i want to compare my similar settings..
Old May 12, 2005 | 01:55 PM
ek2k's Avatar
bump...
Old May 12, 2005 | 02:40 PM
Eclypz's Avatar
skunk2
Old May 13, 2005 | 01:42 AM
Eclypz's Avatar
Default Re: (ek2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2k &raquo;</TD></TR><TR><TD CLASS="quote">yeah i know thats why i have that setting and i was wondering if thats the setting you guys have after tunning your car?? i want to compare my similar settings..</TD></TR></TABLE>
I'm not sure what you're trying to compare exactly.
You can't dial in somebody else's cam gear settings on your car and expect the same results. Different setups like different settings. Some like overlap, some don't. There are just so many variables. If it were that easy, nobody would be going to the dyno and you'll probably see a sticky on here about what works best.
You won't know what works best for your setup until you throw it on the dyno to find out.
Old Jun 13, 2005 | 06:28 AM
fracas's Avatar
AEM--zero'd out!!
Old Jun 13, 2005 | 10:08 AM
Nick M's Avatar
Default Re: (fracas)
AEM 0,0
213whp at 7k, cam gears untouched
i need to have them touched
rdssk8rcs1
Nov 20, 2007 08:29 AM
DB1_559
Sep 10, 2006 06:46 PM
NAlover
Mar 14, 2006 11:52 AM
theleftis
Jan 17, 2006 04:10 AM
SuperTeg95
Jun 29, 2005 11:56 AM
