oil return locatin (please help wanna boost today :)
Old May 12, 2005 | 05:26 AM
RACEPAK's Avatar
Default oil return locatin (please help wanna boost today :)
hello everybody.
is this a good location to place the oil return bunge?
best reargards
Old May 12, 2005 | 05:30 AM
salt's Avatar
Default Re: oil return locatin (RACEPAK)
looks good, just make sure its not right next to a bolt hole, or it will a big pain trying to install it.
Old May 12, 2005 | 06:08 AM
rmcdaniels's Avatar
That's right about where I put mine, it works fine.
Old May 12, 2005 | 06:17 AM
Rod.'s Avatar
Default Re: (rmcdaniels)
look good
Old May 12, 2005 | 10:26 AM
RACEPAK's Avatar
Default Re: (redturbocivic)
ok guys fouble chec, i removed the pan.
this is the spot.
please tell me what you think.
Old May 12, 2005 | 11:19 AM
EJ1 wilcox's Avatar
Default Re: (RACEPAK)
Looks good man...
As long as it is between two bolt holes and clears on the inside of the pan you should be good to go.
Old May 12, 2005 | 11:55 AM
igo4bmx's Avatar
make sure you give enough clearance so you can tighten the fitting on the bung
also do you have like a 45 degree fitting?
Old May 12, 2005 | 12:08 PM
RACEPAK's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">make sure you give enough clearance so you can tighten the fitting on the bung
also do you have like a 45 degree fitting?</TD></TR></TABLE>
k.... thanx ill make sure to give it enough clearance .
yeah i have the 45 deg fitting but it works better like this.
are you guys sure its not too low?
Old May 12, 2005 | 12:12 PM
nerdsports's Avatar
how much HIGHER do you want it? it should be fine there.
Old May 12, 2005 | 12:14 PM
RACEPAK's Avatar
Default Re: (nerdsports)
i dont want it higher this is the bers location for my setup.
civicsaremean
Apr 4, 2008 03:33 PM
K i l l a B e e.
Oct 8, 2007 05:14 AM
Novtecdohc
Aug 31, 2005 04:29 PM
efboy
Apr 7, 2005 07:24 PM
swlabhot
Sep 27, 2004 03:06 PM
