is it possible to pass smog built, boosted, and on AEM EMS?
Old May 10, 2005 | 11:30 AM
H8 O ATE's Avatar
Default is it possible to pass smog built, boosted, and on AEM EMS?
just like the title says, I'm finishing up my build and just got a letter in the mail saying i need to get smogged for registration....any advice?
Old May 10, 2005 | 11:32 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: is it possible to pass smog built, boosted, and on AEM EMS? (Methodmotorworks.net)
is the car obd2 or obd1?
Old May 10, 2005 | 11:33 AM
H8 O ATE's Avatar
Default Re: is it possible to pass smog built, boosted, and on AEM EMS? (wantboost)
originally obd2, its a 99 civic SI
Old May 10, 2005 | 11:36 AM
wantboost's Avatar
Who is Mr Robot?
ok, i have one too. the only thing i have to do with mine here in georgia is they have to pull the ecu codes and readiness test. which requires that you drive about 55 miles or so.
the aem wont do that, muchless an obd1 aem. if you still have your stock ecu, plug it up and put the stock injectors back in and drive it, just dont boost. otherwise theres no way youll pass
Old May 10, 2005 | 11:37 AM
dustin's Avatar
Not in california unless you can "convince" them to waive the visual inspection, or you are in a hick county.
Old May 10, 2005 | 12:38 PM
tgreaves's Avatar
Default Re: is it possible to pass smog built, boosted, and on AEM EMS? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Not in california unless you can "convince" them to waive the visual inspection, or you are in a hick county.</TD></TR></TABLE>
That sucks, you all have a visual inspection..
Old May 10, 2005 | 12:45 PM
turboman's Avatar
I've gotten my civic to pass with no cat at all. Lean it out alot and turned the boost all the way down. Hmmm any way to leave the waste gate open?
Old May 10, 2005 | 01:46 PM
turbodohcsi's Avatar
you could possibly pass if it was a sniffer test on and obd1 motor, but there is no way to pass with an aem on and obd2 motor, cause you cant throw codes. do like the other guy said and put your stock stuff back in for a minute and go get it tested.
Old May 10, 2005 | 01:49 PM
H8 O ATE's Avatar
Default Re: (turbodohcsi)
stock as in, injectors and ecu, or take out the turbo?
Old May 10, 2005 | 02:06 PM
injectors and ecu, and whatever else you have modified that would throw and emission related cel.
Old May 10, 2005 | 04:22 PM
mildly.interesting's Avatar
signs point to no....
Old May 10, 2005 | 04:56 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (mildly.interesting)
lol, you and your magic 8ball
Old May 10, 2005 | 05:07 PM
SFWD 1934's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mildly.interesting &raquo;</TD></TR><TR><TD CLASS="quote">signs point to no....</TD></TR></TABLE>
I heard that . . . . Funny thing on my 98' Prelude turbo, I thought that I would just drive nice and easy, and all would be good. Turned out, it failed the first test, had to rev it up a bit and get rid of some of the build up to get it to pass the second time. Yes in California we have visual. Sometimes you can find the guy that will "look the other way" if everything passes.
Good luck,
Jason
Old May 10, 2005 | 05:42 PM
slywfbpsi's Avatar
Default Re: (SFWD 1934)
It's a good thing nc is getting rid of the sniffer test next year, on all pre odb2 cars, just have to make sure I'm running a cat.
Old May 10, 2005 | 05:44 PM
bwhahahahaha NC here too...no cat, nearly blind you standing behind the car at idle, blows a 3 foot flame out on downshifts....I pass every time, but I do work at the stealership. It's nice to know folks...
drummerdude
Engine Management and Tuning
Jul 13, 2009 07:44 PM
shortdahri
Apr 1, 2006 05:50 PM
96MidoriHatch
10
Mar 7, 2005 06:11 PM
EX-T
Nov 3, 2003 08:20 AM
