ARP Headstuds for D16Z
I have a D16 sitting around I plan on boosting very soon, but before I do...should I replace the headstuds with ARP ones? I will be pushing a t3/60 at 7psi. Would it benefit me any or would it just be peace of mind to get them?
*I will be replacing all seals/headgasket/timing belt etc before boosting while the motor is out.
Thanks
Rich
Thanks
Rich
I wouldn't if you are just going to do 7psi. But then again, if you plan on upping boost in the future (more than likely), they are good insurance against leaky headgasket issues.
7psi will be the set boost forever. This is jsut for a daily driver...a long term daily haha. Iv'e already had a high boost b series and just wanted to know if this would be benificial to my setup to run a daily driver at 7psi.
thanks for the repies so far!
I would definately put the ARPs in...
I had head lifting issues with my d16z6 at 7-8 psi within 4 months of boosting... I installed some ARPs and a new head gasket, haven't had any problems since...
You might as well put them in there, you will probably need them sooner or later anyways.
D series heads are notorious for lifting. I'd get a set for any amount of boost. We have them on sale here:
http://www.importparts.com/sho...=4899
Actually, you know what, I'd go ahead and get them no matter what. It's one of those things that pays for itself in the long run.
It's like my Hondata gasket. I don't care what it does performance wise, but just the fact that I can re-use it is soooooo nice.
If you ever have to pull your head (very likely) to diagnose a problem, it's really convenient not having to go to the dealer and buy new head bolts.
