What turbo?
Old May 6, 2005 | 12:57 PM
vamz's Avatar
Default What turbo?
I know you guys get a lot of these questions, but I am not en engine guy. . . I can design my own suspensions, but engine are really foreign to me.
I am building a b16a, bored out to 1.8 liters, stock cams, ferrea valve train, 1mm oversized valves, 8.5 pistons, darton sleezes, micropolished crank. So a pretty heavily built engine, what turbo should I get if I want 250 daily driven and like 500 at the track with pump gas. I need a turbo that can be driven on the street, but also that can handle the 500hp. Thanks for the help.
Old May 6, 2005 | 01:19 PM
rmcdaniels's Avatar
Default Re: What turbo? (vamz)
https://honda-tech.com/zeropost...37371
Old May 6, 2005 | 01:21 PM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vamz &raquo;</TD></TR><TR><TD CLASS="quote">I know you guys get a lot of these questions, but I am not en engine guy. . . I can design my own suspensions, but engine are really foreign to me.
I am building a b16a, bored out to 1.8 liters, stock cams, ferrea valve train, 1mm oversized valves, 8.5 pistons, darton sleezes, micropolished crank. So a pretty heavily built engine, what turbo should I get if I want 250 daily driven and like 500 at the track with pump gas. I need a turbo that can be driven on the street, but also that can handle the 500hp. Thanks for the help.</TD></TR></TABLE>
I'd like to know how you bored that out to 1.8L.
Old May 6, 2005 | 01:36 PM
rmcdaniels's Avatar
Well, it's sleeved, so if he's running a stock 77mm crank and bored it to 86mm, then he'd be about 1.8, of course his cylinder walls might be a bit thin.
Old May 6, 2005 | 01:52 PM
liam821's Avatar
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Well, it's sleeved, so if he's running a stock 77mm crank and bored it to 86mm, then he'd be about 1.8, of course his cylinder walls might be a bit thin.</TD></TR></TABLE>
Yeah i dont think i would go any bigger then 85mm on a turbo motor.
Old May 6, 2005 | 01:54 PM
_entropy's Avatar
Even 86 is a bit short of 1.8. I think he may have been thinking of 84mm sleeves, and thinking that 84mm on 1.8 = 2.0, even though it = 1.93 on a GSR, and thinking 84mm will add .2L of displacement to his B16
Old May 6, 2005 | 01:59 PM
rmcdaniels's Avatar
Default Re: (Napoleon Dynamite)
I figured 1.79 was close enough to call it a 1.8, but I think you're right, he's got an 84 or 85mm bore and hasn't done the math.
Old May 6, 2005 | 02:02 PM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">I figured 1.79 was close enough to call it a 1.8, but I think you're right, he's got an 84 or 85mm bore and hasn't done the math.</TD></TR></TABLE>
I don't even know if his sleezes could hold an 86mm bore
Old May 6, 2005 | 02:07 PM
rmcdaniels's Avatar
That could be it, maybe Darton sleezes are stronger than the regular sleeves.
Old May 6, 2005 | 08:19 PM
vamz's Avatar
It started out as a b16, it is bored out to almost 1.8 liters, not quite. Darton sleeves are much stronger than stock.
And that link didn't really help all that much.
Old May 6, 2005 | 08:23 PM
_entropy's Avatar
Default Re: (vamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vamz &raquo;</TD></TR><TR><TD CLASS="quote">It started out as a b16, it is bored out to almost 1.8 liters, not quite. Darton sleeves are much stronger than stock.
And that link didn't really help all that much.</TD></TR></TABLE>
So what bore is it?
84mm takes you to a little bit over 1.7 litres, and anything more than that really isn't the best choice for turbo.
rmcdaniels's Avatar
Default Re: (vamz)
Did you check out the links I posted in that thread?
http://www.turbosaturns.net/ar...s.htm
http://www.turbosaturns.net/ar...2.htm
Old May 6, 2005 | 11:28 PM
sa90eg's Avatar
sc61 is the way to gooooooooooooo...
TealCivic115
Aug 27, 2011 03:27 PM
EG 4619
13
Mar 25, 2005 06:24 AM
I2ice0pride
Honda S2000
Dec 25, 2004 12:10 PM
