Injector tapping?
Old May 6, 2005 | 05:23 PM
Mr. Vapor's Avatar
Default Injector tapping?
Just got my DSM 450 blue tops installed and had the car running today.
Fuel set up is as follows:
DSM 450s,
Uberdata
Walbro 255lph HP intank
stock rail
fuel pressure: 45psi idle.
at idle, these injectors are LOUD as ****. at first i thought i was getting some piston slap since hte motor was cold at start up. then i thought it was the valves tapping? but upon closer listen its definatly my injectors.
what does this mean? normal for this injector? or is this a problem?
Old May 6, 2005 | 05:38 PM
EGhatch4991's Avatar
Default Re: Injector tapping?
it was normal for me.. i have slighty bigger injectors and there loud as **** so im assuming with 450's it should be .
Old May 6, 2005 | 05:51 PM
VisualAutoMotoring's Avatar
Default Re: Injector tapping? (EGhatch4991)
Its normal. Almost sounds like your motor needs a valve adjustment.. SR20DET stock injectors do the same thing
Old May 6, 2005 | 09:58 PM
Mr. Vapor's Avatar
Default Re: Injector tapping? (Hybrid-Performance.com)
exactly....sounded like valves! ok just checking.
Old May 7, 2005 | 12:57 AM
_Cyclone_'s Avatar
Default Re: Injector tapping? (Mr. Vapor)
So is that normal for all the bigger injectors? I'm going to throw my DSM 450's on in a couple of hours... I just have to find some OBD 1 clips in the junk yard.
hysteria411
Engine Management and Tuning
26
Sep 30, 2013 06:12 PM
nus_dogg
May 20, 2012 07:26 PM
95dc2teg
Aug 18, 2006 11:26 AM
ZERO COOL
Jul 15, 2002 05:36 PM
