did b18b swap at idle surge
I had this problem with my LS when I went all motor, for me it was the tps was not sitting right at idle. Make sure you adjust the throttle using the throttle cable and it should sit at .49 volts at idle. After you check that, go after the IACV take it off and clean it out really good. Then look for vacuum leaks.
DIYMIKE
May 19, 2005 01:15 PM
