bouncing idle...
my idle is bouncing between about 1100 - 2000 rpm and I'm not sure what the problem really is. I thought it was the throttle cable at first, but even with careful adjusting it's still jumping like crazy... could it be spark misfiring, one of the belt fittings, a sensor not reading right, etc.? suggestions anyone??
before you go replacing a bunch of sensors check the vacuum lines i made the mistake of relpacing my tps and iac before checking the vacuum lines and sure enough it wasnt the sensors but a vacuum line leak
I had the same problem...found out it was the throttle body gasket. I was using a B16 gasket (LS tb...B16 manifold) and air was leaking at the bottom.
